Side bumper strips for RX 450h
I have a 2010 RX450h with all the options available in Canada on order and expect delivery on January 27, 2010. I asked the dealer today if I could get side bumper strips installed to protect the doors when the vehicle is in parking lots and he did not know. He promised to look into it. It seems that they were standard on the RX 330 until 2009.![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Does anyone have any comments? I suppose I could always go to a body shop for them.
Many thanks.
Many thanks.
You can get an aftermarket piece on ebay, also, if you want OEM, just get the ones for the GEN2 RX. It will fit on the GEN3 RX.
http://cgi.ebay.com/ebaymotors/ws/eB...m=270506549996
WyouO1
Thanks for your advice. I will follow up with the dealer about using the parts designed for the Gen 2 vehicles.
Last edited by oscqc; 01-10-10 at 06:46 PM. Reason: Correction in spelling his name
I've heard that the dealer can install these (parts made for the 3rd gen). Just be aware that they will be mounted using adhesive (some sort of automotive two sided tape?), whereas the previous generation were actually clipped to the vehicle. For this same reason, I'm not sure that the 2nd gen will work on the 3rd gen unless they remove the clips and use adhesive. If that's the case, you might as well get the proper parts that were made for the 3rd gen.
No, I don't play soccer!
oscqc, the dealer can install the side door molding like rcy said. Mine is charging between $500-600. I didn't look at it close up to see how it was mounted because I wasn't interested in it.
Where will you mount them on the vehicle so they will protect you car? With all the different types and styles of vehicles on the road it will be impossible to protect you paint with just a rail. Most of the rails put on these or any other vehicle are put there to break up the bland style of a vehicle.
