Rx 400h interior cig light
Hello all,
I'd like to ask for help with regards to the cigarette lighter inside a 2006 lexus rx400h.
I swear I remember them being lit, i'm talking about the little round plug next to the seat heater controls in the center lower dash. Can u guys check ur car at night to see if there's a light around the ring of the cig lighter??
thanks so much!
andrew
thanks so much!
andrew
Not lit. Apparently, the 12 volt outlet ring was lit up on the RX300. Someone on the other board has modded his 400h by putting the 12 volt outlet from a 300 in his 400h.
Kinda foolish on Lexus's part. The drink holder which you can't miss even in the dark is lit, but the tiny 12volt outlet is not.
thank you
weird, after thinking that it was lit before, i went on youtube and found that someone elses' rx400h had the cig ligter area lit. Although it may be because it was a rx400h from italy.
thanks for checking ur cars!
andrew
andrew
