Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Lexus Rh 400 2008 questions
Old 03-07-10, 04:56 PM
priyasrik
priyasrik's Avatar
Default Lexus Rh 400 2008 questions
We just bought a Lexus RX 400H 2008 model with 14K miles for 35,888.
While driving back from our dealer ( 300 miles from our city), we noticed a couple of things:
1.The temperature kept blowing cold air till close to 77. The outside temp was 61.
We felt it was a little weird that we had to turn it up to 80 or so to get hot air. Is this a problem? Any insight is appreciated.
2. The MPG on the panel kept showing close to 22MPG but when we did our quick calculation, it came close to 27. Is the display not tbe trusted at all?
thanks a lot.
Old 03-10-10, 11:07 AM
BobBass
BobBass's Avatar
You should not have to set the temp at 80 to get "hot" air. I have found the HVAC system on the 400h to be very good and pretty much "set it and forget it." I AM into turning the compressor off whenever possible (dry winter conditions and early spring/late fall) and ALWAYS for the last minute or so in the summer before parking the vehicle.
If you're new to hybrids and want to squeeze maximum MPG out of it, you will turn the HVAC OFF if conditions warrant. It's always interesting; if you pull up to a red light, the CAT converter is fully warmed up but the coolant still has to be warmed up to deliver heat and you have the HVAC set to heat the interior, when you push the "OFF" button, the engine will instantly shut off.
As far as the MPG readout, I have never checked mine using the "manual method." I think most owners say the readout is fairly close...certainly within 1 mpg.
Old 04-18-15, 02:17 PM
lexusNUA
lexusNUA's Avatar
I have 2008 Rx 400h; 131,000 miles sometime I notice it is blowing hot air while I set it to 70 and outside temp is 82 degree. Sometime it signals WATER TEMP. Lexus mechanic said may water pump problem and ask me pay almost $1800. Any suggestion.
Old 04-19-15, 08:25 AM
thomas1
thomas1's Avatar
I serious doubt it is a water pump problem. Probably has more to do with climate control servos that actuate the blend doors in the heating and cooling under the dash. As for Water temp, have never had that, but I would surely make sure that you are not loosing coolant from your radiator. If you are it could be a radiator leak or yes the water pump leaking but these would result in coolant level going down.
watt2
ES - 5th Gen (2007-2012)
07-27-18 08:11 AM
Woolly168
01-14-16 09:31 AM
bigwave
Hybrid Technology
08-25-08 10:14 PM
LVLarry
GX - 1st Gen (2003-2009)
15
02-19-08 04:37 PM
ajmtbm
11-24-07 03:26 PM
Quick Reply: Lexus Rh 400 2008 questions
