GS450h OEM Run Flat Problems?
I have an '07 with 20k miles. Lots of tread left on all four tires. Left front was losing about 6-8lbs/week for the past few weeks. Almost zero pressure today. Tire shop showed me that all four tires were separating on the inside of the tire. Now I need 4 new tires. Ever heard of this? Thinking of ditching run-flats for regular 245/40-18's. Thoughts?
executive matchup
at 20k miles the dealer more than likely won't replace them for you. I will not be considered a warranty issue as 20k miles is well beyond the "premature wear" stage. I would, however, consider all the options for the non runflats. You will be much happier with the wear/ride, and life of the non runflat tires.
The advantages of run flats are:
1) firm side wall means car is flatter during cornering
2) much safer in event of a high speed puncture
3) ability to drive on a flat tire so you don't need a tow or to change the tire on the side of the road.
disadvantages are:
1) more likely to wear out early as you experienced
2) firmer handling and ride also means you feel bumps more and worse ride quality
3) more expensive
Yeah but if you had factory run flats then this would just be a consequence of having low performance tires. What I am saying is that the firmer sidewall of the Michelin PS2 run flat results in better handling but worse ride than the Michelin PS2 regular tire.
Runflats, in my experience, are nothing but aggravation. Just check the reviews at a place like tire rack, people almost universally hate them. Had my GS350 come with run flats I'd have ordered a spare tire and regular rubber the day I bought it.
On the other hand, I suppose it would be nice not having to change a spare on the side of the road...
Tire rack surveys also suggest a slight edge for the PS2 runflat on cornering stability, however the survey results are strikingly close.
