Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
RX 400h Inverter Problem
Old 04-25-16, 06:48 AM
  #46
jooksing82
jooksing82's Avatar
Originally Posted by smassey321
If that were my car, and it probably will be some day, I would wipe it off and keep an eye on it. My transmission had a similar leak and it took 6 months until it got bad enough to leave a drop on the garage floor. The dealer actually did not change it under warranty until it got worse than what you currently have.
Once it got bad enough to make a mess I would disconnect the batteries, drain the coolant and pull the inverter so I could take it apart and see what is going on in there. Although I have never seen one apart, it sure looks similar to replacing a leaking oil pan seal. The dealers only replace things like this so there is not a lot of info on how to actually repair.
While you have the inverter out change the thermostat in the gas motor as the inverter is completely in the way .
Yup that's my game plan. While searching the interWeb I came across the directions to remove the inverter and thermostat on autozones website. It looks pretty straight forward except the very end it said "perform the initialization procedure, as outlined in the Chassis Electrical System."
Old 06-14-16, 12:40 PM
  #47
Benjaminx
Benjaminx's Avatar
Hi there, would you tell me where is the inverter cooling water pump located at on 2006 Lexus rx400h?? Please help.. Thank you
Old 06-15-16, 04:49 AM
  #48
smassey321
smassey321's Avatar
It is behind the normal radiator on the inverter side. Take off the plastic front cover of the inverter and look down and it is close to the lower edge of the radiators. It is external from the engine hanging off some brackets. Look for the hoses and wires.
Old 06-15-16, 08:19 AM
  #49
thomas1
thomas1's Avatar
Very easy to replace, cost around $200. Mine failed around 100k miles, It is a little electric water pump basically. When mine failed Toyota replaced it, but they had to reset a lot of stuff.
Mgaz (09-15-23)
Old 08-28-19, 10:55 AM
  #50
fogler833
fogler833's Avatar
Any updates from the people who had inverter leak? Does it get worse over the time? My 2008 400h inverter started leaking. My leak exactly looks like the one in posted in #44.
Old 01-29-20, 01:13 PM
  #51
jooksing82
jooksing82's Avatar
Looks like it does not leak much. its covered by a layer of dust now.
Old 05-18-24, 09:04 PM
  #52
dedas1
dedas1's Avatar
Hi everyone. glad these are here for us to review forever. Our 2008 RX400h has only 68k since mostly city driving. it has been garaged for the last year an half due to 2 episodes of catalytic converter rip offs. We finally started driving it again and noted a small stain on the garage floor. I haven't been able to locate exactly the site of leakage, but seems like coolant from the inverter.
From the post on #49, sounds like the pump is easy to change out. The inverter replacement sounds prohibitively costly, more than the car is worth at this time.
Question
1. If the inverter doesn't fail, why can't I just keep filling the coolant back up.
2. If the transaxle is the source of the leak, will filling the inverter coolant keep it also filled up and keep from failing?
3. It sounds like there is trouble only if the inverter itself fails?
Anyone scanning this thread with any help or suggestions is appreciated.
thanks
celiothrkn
RX - 3rd Gen (2010-2015)
07-17-17 10:41 AM
first400h
Hybrid Technology
10-14-14 10:14 PM
sneakyazn
Hybrid Technology
05-22-12 02:35 PM
iwantlexus
Hybrid Technology
05-17-10 09:49 PM
RNDRX
05-02-09 11:26 PM
Quick Reply: RX 400h Inverter Problem
