Increasing tire pressure
Hi all,
I did a search. and unless I just didnt get it right, I did not see anything specific on this(Please link if you see a post though ).
My 450 has the 19" Michelin Lattitude tires on it. According to my pressure monitor, they are set to 31-32psi cold.
Has anyone tried increasing their tire pressure to 35psi cold? I did this on my other vehicle and actually got 2mpg more.
Just curious if anyone has done it and noticed an improvement. Might give it a try. Worst case would be a little rougher ride.
Super Moderator
I've done it for years on my RX300. My Michelin 235x70x16 CrossTerrains have a max of 44 psi and I run them at 38 psi. It is a rougher ride, but MPG has been better and of course when I used to run the 1/4 mile it was always faster.
Hi all,
No, I don't play soccer!
I keep mine at the recommended 33 PSI with the Dunlops. Dealer had it around 36-37 PSI when I picked it up in January. The ride was tight and firm but I brought it down to specs. Now with the warm weather, it goes from 33 to 37-39 PSI after driving a few minutes. That's high enough for me.
The low tire pressure warning goes off at 30 PSI. I found the monitor tends to read slightly lower than the tire gauge by about a pound. And the tire pressure display order is random. So I break out the trusty tire gauge to check them every few weeks.
Domo-Kun
02-18-05 10:41 AM
