Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
New fog lights, DRLs and parking lights for the RX450h
Old 07-24-10, 07:57 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
Smile New fog lights, DRLs and parking lights for the RX450h
The color of the DRLs and fog lights have been bothering me since I picked up my RX450h. The yellowness, or more like dirty white, clashed with the LEDs and basically looked cheap. Now I know I could just turn off the DRLs but I need the fogs to see at night due to the anemic light output of the LEDs. So I hooked up with an installer Friday to change them out along with the parking lights.
The DRLs were easily accessible through the top. The parking lights were tricky because they’re blocked by the LED headlight casing. Finding and installing the bulbs had to be done by touch. Below is the view looking straight down the passenger side. The DRL cover is partially obscured by the frame at the bottom (picture 1),
For the DRLs, super bright xenons were used. The bulb is blue and gives off a nice blue hue to the light casing. It’s perfect for the h. Check out the old DRL bulb after six months. Pretty bad oxidation going on there (picture 2).
To get to the fog lights, the covers underneath the engine were removed and the forward part of the wheel well cover was moved. The passenger side fog install was pretty simple, driver’s side not so much. The trans cooler sits behind the fog light. This is the view taken from the front wheel well cover on the driver’s side. The fog light is partial white ring to the left (picture 3).
Overall, the install wasn't bad at all. I think it took longer to remove/replace all the covers and make sure all the clips and screws made it back to their proper place.
Here are a few dusk/early evening shots. First, the LEDs with high beams on at an angle (picture 4).
New LED parking light (picture 5).
I haven’t been able to take decent pictures of the new 6K fogs at night because of the insane humidity around here. I hope to do that soon.
A big thank you to Vinnie and Joe at Audio Expressions for doing an awesome job
Edit: Sorry for the problems seeing the pictures Hope this works for everyone.
Attached Thumbnails New fog lights, DRLs and parking lights for the RX450h-1.jpg   New fog lights, DRLs and parking lights for the RX450h-old-drl.jpg   New fog lights, DRLs and parking lights for the RX450h-fog-inside.jpg   New fog lights, DRLs and parking lights for the RX450h-5.jpg   New fog lights, DRLs and parking lights for the RX450h-led-parking.jpg
Old 07-24-10, 11:11 PM
RXSF
RXSF's Avatar
like the new parking lights. Id rather drive with the parking lights as DRL instead of the standard DRLs. These looks more like the new LED strips that are coming off every new car
Old 07-25-10, 03:40 AM
Cruiter
Cruiter's Avatar
Default Overcoming obstacles
Super job Anita.
I'm beginning to think that the lack of easy accessibility will mean that a few years/miles down the road there will be a lot of our cars being traded with blown bulbs .
The courage and determination of yourself and a few others are showing that long term bulbs can be installed but I doubt the majority of the owners will go this route. Especially when they find out what Lexus rates will probably be to change a blown bulb .
Old 07-25-10, 04:21 PM
kitlz
kitlz's Avatar
Here's another picture I meant to include. It's a side by side comparison of the old vs. new DRLs which are also the high beams. What a difference.
Attached Thumbnails New fog lights, DRLs and parking lights for the RX450h-side-by-side.jpg
Old 07-27-10, 03:35 AM
spoon808
spoon808's Avatar
o_o" something must be wrong with my browser. I don't see pictures, not even little "x"s in place of pictures.
It's like it doesn't exist.
Old 07-27-10, 06:39 AM
kyo7878
kyo7878's Avatar
^ same here..... -_-"
Old 07-27-10, 07:47 AM
ziggy1
ziggy1's Avatar
Yes, no pictures to be seen and a shame since you obviously put a lot of effort into this post! Thanks for giviing us this info!
Old 07-27-10, 08:29 AM
kitlz
kitlz's Avatar
Sorry, I don't know what's wrong. I can see them but there has to be some kind of problem. I'll try to fix it later.
Old 07-27-10, 11:19 AM
Cruiter
Cruiter's Avatar
I see them just fine. Must be your settings
RXSF
RXSF's Avatar
I no longer see them...
Old 07-27-10, 11:29 AM
Joeb427
Joeb427's Avatar
I don't see them,either.
Old 07-27-10, 03:30 PM
kitlz
kitlz's Avatar
OK, the pictures should work now (fingers crossed).
Old 07-27-10, 06:26 PM
wa3cuj
wa3cuj's Avatar
Can't see them here. Maybe it's a setting in my browser.
Old 07-28-10, 04:10 AM
Joeb427
Joeb427's Avatar
I see the pics.
Anita,do you know what brand bulb was installed in your DRLs?
Old 07-28-10, 07:55 AM
kitlz
kitlz's Avatar
Originally Posted by Joeb427
I see the pics.
I believe the DRLs are Litech. I let the installer go with bulb selection since he knows more about them than I do. Even better, any problems and I go back to him. Realistically I should get a few years out of them. They're not that expensive.
Quick Reply: New fog lights, DRLs and parking lights for the RX450h
