RX400H with 135,000+ miles
My 2006 RX400H is currently sitting at over 136K miles. I love the car and would like to keep it, but the way I'm going, I'll be over 200K before the car is paid off. I want to see if anyone knows a life expectancy for the 400H or if there is anyone out there with more mileage?
Thanks
Thanks
BTW, for all who are wondering: Still runs great, no battery problems (shhh), still get 25+ mpg, the only part i've had to replace is a windshield washer motor and the tires. I do the regular maintenance/oil changes, and use premium gas (93 octane) from Shell or Chevron only. I use to use the cheap to mid gas or any gas station (when gas was nearly $4/gallon), but noticed a little knocking, so I switched back to the premium. Hope that helps others out there!
Does anyone know if they even replace the water pump when doing the timing belt? Only reason I ask is that the water pump on the 400h is electric, not your traditional belt or gear driven pump. I imagine the reasoning behind changing it might be the same (they are already in there to get at the timing belt, why not change the water pump), but I don't know if the electric water pump suffers from the same wear as a traditional water pump (worn bearings I guess being the most common).
re. the comment about big repair bills if timing belt not changed. This is true for an interference engine where a failed timing belt can cause the pistons to contact the valves resulting in bent valve stems or damaged pistons. I believe that these are non-interference engines, meaning no additional engine damage will occur if the belt fails in service- just inconvenience and towing charges. Repair costs should be the same as with a planned replacement.
My mistake, there is a traditional water pump for this engine driven by the timing belt. The electric pump that I'm thinking of (the auxiliary pump - see below) keeps the coolant circulating even when the engine if off (but the car is in READY mode) so that cabin heat can be maintained.
Just did a quick online part search...there is a water pump for $97.80 and an 'auxiliary water pump' for $482.18. There is also the water pump for the hybrid side of things (the one that pumps coolant through the inverter) that is $392. The inverter pump is electric for sure and isn't anywhere near the timing belt.
I did some digging on the internet about the toyota 3.3L V6, which is in the 400h and this is what I found:
The 3.3L 3MZ-FE engine is a rare example of a Toyota engine with timing belt that is an interference. In most cases, Toyota engines with belts are non-interference, but the 3MZ is a rare exception.
FYI: The 3.5L that is in the 450h has a timing chain. I find it interesting that import cars are going back to using timing chains.
Interesting. My Subaru Outback (gone now) with the H6 was also a chain.
Decision time now..$600 for timing belt job, or.....$60000 for a 450h to save the $600 on the timing belt...lol.
I called the Lexus dealer and the Toyota dealer near where I live. Lexus was $600 (timing belt only, no water pump). Toyota was $500 (again, timing belt only). Both said they inspect the water pump, but in their experience, they usually are not weeping etc., and can be left in till the next timing belt change.
@Brian- ummmmm.... I've done all the standard 30/60/90/120 maintenance and everything in-between. They have never told me that they replaced the timing belt or water pump. Is this something that they would be inspecting during my oil changes etc? BTW (not to be stereotypical), but I'm female and wouldn't know a water pump if it hit me in the face So please take this as a serious question. Thanks
