GS 450h MPG
I always wondered what is the difference in terms of MPG if i engage the virtual gear in 6th gear vs. "D" position in auto.
I noticed a slight increase in MPG with my GS300 with the gear in 6th at all times.
Im guessing that the car rarely shifts beyond 5th gear when in "D" position thus explains the slight MPG increase when the manula gear is placed on 6th.
Neu`roc´i`ty
I cant see any on the GS450h because there really isn't a gear box like the 300's, 350's, 430's and 460's. What i am assuming is the electric motor is providing more drive momentum till the 3.5L kicks on. Lets face it...the gas pedal in the GS450h really is sending a command to a computer than it is an accelerator. You cant really rev up the engine with the gas pedal.
i used to get right under 25mpg...just about always pushing.....i recently got new tires ( goodyear eagle gt , non runflat, still dont have a spare)...and under same driving conditions im averaging slightly above 26mph...even spit highway and city....my best 100% highway is 33mpg
just thought id throw that out there...
I've now had my 08 GS450h for a week.
While driving back from the dealer, all freeway I got 31 mpg.
After a week of both freeway/city driving for 330 miles. I was surprised that I still had 1/4 tank left and filling up this morning I calculated I averaged 26.27 mpg. Almost double what I was getting on my GX so I'm thrilled.
Former Sponsor
50-mile-per-day commute with half at higher (55-60) speeds and half at low (35), I average about 25MPG with my foot in it. I can get 27+ if I drive "normal".
On long trips, my car LOVES 78-85 MPH and will get over 30MPG if I keep the speeds up in that range. If I drop to low 70's, then my MPG drops to about 29-ish. Best tank average was 30.6MPG an averaged 77MPH for the tank.
BTW, I have nearly 95K miles on it... I use ONLY high-end (AMSOIL) synthetic 0W50 oil with OEM filter. Tires are at 35PSIG, and I check them regularly. I usually run a bottle of Seafoam or B-12 Chemtrol through the injectors about once every 3 months or so (about 10K-12K miles for me).
Do you only use premium fuel?
Guest
Posts: n/a
I agree with you on this. Just did about 400 highway miles roundtrip over the holiday. The car showed 30.1 mpg for the trip. I calculated 29.8. I was in the 70-80 mph range the entire time. Something about that speed seems to make the car get better mpg. On previous trips, done at a lower speed, my mpg's were in the 25-27 mpg ballpark. No complaints though, as that is stil good for a performance car imo!
I've had my 09 GS450h for a few months now. I'm an aggressive driver and do a mix of city and highway. Every tank so far between 25.5 and 26.5.
Have never done a full highway tank.
I'm on run flats which I'm assuming hurt mileage.
