Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Machine mount quad HID projector near completion
Old 10-07-11, 04:17 PM
mowmow
mowmow's Avatar
James, the new bezel is a E46 replica and all 6 ballast ( 4 in the headlight 2 for the fog light )are all high output ballast, new harness had to be made.
Old 10-07-11, 04:22 PM
infinirx
infinirx's Avatar
Can it be done again now that this one is working?
Old 10-09-11, 10:01 AM
mowmow
mowmow's Avatar
After 5+ hours of install, here is the finish product
Passenger side DRL
Driver side DRL
All 3 projectors on driver side + DRL
All 6 projectors are running on hyper ballast
-Low beam at 75Watt vs 35Watt factory
-2nd low beam (high beam ) at 65 Watt of HID vs factory halogen bulb
-Fog light also at 65 Watt vs previous upgrade of 35Watt cheap hid kit
-Factory DRL was disable following instructions found on the forum
-Factory AFS retained
Old 10-09-11, 11:01 PM
infinirx
infinirx's Avatar
Would love to get them w/o the led strip Not my style but looks great with your set up!
Old 10-10-11, 09:26 AM
mowmow
mowmow's Avatar
James, you can email the my friend see if he can do one for you, mind you it does take time to build and his labor cost is definitely not cheap. Not to mention hyper ballast is extra
Old 10-10-11, 09:06 PM
mowmow
mowmow's Avatar
Here is the driver's view cutoff line
Low Beam
High beam
Old 10-10-11, 10:23 PM
infinirx
infinirx's Avatar
So it looks great. Do you have the high beams on at the same time or are you using them primarily for really dark roads?
Old 10-11-11, 09:58 AM
mowmow
mowmow's Avatar
I hardly have to use the high beam because when all 6 projectors are on, it's very bright already, remember I have 205 watts of light per side ( 75+65+65)x2 , a total of 410watts
Old 10-11-11, 11:55 AM
infinirx
infinirx's Avatar
So your daylights that were converted have the high beams for dark roads and HID's that are on all the time and are shown in the first pic?
Old 10-11-11, 10:45 PM
mowmow
mowmow's Avatar
Yes, all 4 projectors are on then fog lights that makes 6, high beam use for dark roads and to flash those idiots that try to high beam me despite I have the headlights professionally aimed.
Old 10-11-11, 10:54 PM
infinirx
infinirx's Avatar
Can you take a pic of the ground area near the cut off with all six then with just the usual four?
I would love to talk to the guy that did the work and work out something.
Old 10-12-11, 02:34 PM
mowmow
mowmow's Avatar
Okay, I will try to do it sometime this week if I have time, work has been super busy this week
Old 03-09-12, 04:08 PM
mowmow
mowmow's Avatar
Here is the front view of my RX with the retrofit in.
Old 03-09-12, 04:24 PM
MrBruin09
MrBruin09's Avatar
Wow, looks great!
Old 03-12-12, 02:49 PM
mowmow
mowmow's Avatar
Thank you, it's very factory looking, at night time all 6 goes on, I have a total of 410Watts illuminating the road
Quick Reply: Machine mount quad HID projector near completion
