89 octane, worse mpg than 87?
Hi everyone,
So I know there are a bunch of threads about mpg, but I have a weird situation here. My 2011 RX450h has about 3300 miles and I have only ever used 87 octane gas. (My salesman told me this is fine, and I should only go higher if I hear knocking, which I never have.) I've recently been getting 27.5-28 mpg pretty consistently, and even 29.5 on long stretches of highway.
After reading some of the other threads, I decided to try a tank of 89 octane. In my area, it's about 5% more expensive than 87, so I figured if I could top 29 mpg in city driving, it would be worth it. I was nearly empty at my last fill-up, so I loaded it up with 89.
Well wouldn't you know, I've gone through about half a tank, and done only my normal drive that I do every single day (almost all city stop & go, with some highway, moreso on the weekends) and have plunged to 23.5 mpg. When I give it the gas, the engine seems to make a much throatier sound than before, like the difference between being in a 4cyl and a V6.
I can think of a few possible explanations: I got some "bad gas"; my (h) was perfectly happy with 87 octane and is not adjusting well to the change; or the fill-up happened to coincide with some other kind of problem.
Not sure if it's related, but soon after I got it, I tried Eco Mode for a while, and noticed that my mpg was actually much worse than usual. It seemed to stay on battery power for longer when at low speed on flat surfaces, but needed to work much harder to get up hills, and I think the decreased horsepower was negated by the extra fuel required to move with the less-powerful engine. This sounds contrary to what other people on the forums describe of their experience in Eco Mode, so it could be more evidence for an engine problem, or it could be completely unrelated.
Anyone seen anything like this before?
The manual say 91 octane is require, not 89 octane. I would try at least 5 or 6 tanks of 91 octane before you come to any conclusion about milage. You salesman is mis-informed as well, all new cars have knock sensors, so using a low octane on the RX will not cause the engine to knock. Usually, the low octane does cause the engine to run rougher and decrease power and gas milage. It sounds like you are gasing the engine too much with the high octane. Maybe thats why your gas milage decrease so much. Try taking it easy and accelarate at a normal rate and calculate your milage manually instead of using the MPG computer.
Doing the calculation manually is a good suggestion though. I did this for the first several fill-ups after getting the car and it was always spot on (well, assuming you trust the odometer, of course) so I didn't think to question it. When this tank runs out, I'll reset the trip meter, give it another tank of 89 and see what happens.
Really, I was just trying to figure out how it's possible that switching to a higher-octane gas would reduce the mpg by that much, and if it's an indication of some kind of engine trouble. The car is only 3 months old at this point and I'm still learning the ins and outs.
It is summer time, if you are running with the AC on, that could be a factor.
Also, if you fill up during a hot day, the fuel will be less dense, another factor.
Maybe something is wrong with that gas station.
Many things to consider, can't really give you a clear answer.
From my experience, driving in NYC uses more gas than outside of NYC.
A local news crew did an expose on ethanol levels using lab tests. Even though the stickers on the pumps here say "up to 10%" their tests showed results all over the map (many wat over 10%). When I can find ethanol free fuel I get better mileage. So maybe we are also dealing with an ethanol variation in this thread also.
I'm lucky to have many locations where I can get 100% gas and always run 87 and steadly average 32-34 during summer and 31-33 winter (we don't have winter gas here). I'm over 10,000 miles and very pleased with this vehicle.
Bob
Bob
In Mobile on the coast the only place you can get it are places that are selling for boats and they do it at a premium price that might be .50 gallon more than 89 with Ethanol.
Once again I feel even more lucky now for I usually only pay about 5 cents more for it. There are about a dozen stations near me that have 100% gas and some of them do ask to much for it but there is one right near where I live and he keeps his just a little above 87 and sometimes it's the same.
Bob
Bob
