Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Has anybody changed the headlights bulbs?
Old 06-28-11, 02:45 PM
wcntan80
wcntan80's Avatar
Default Has anybody changed the headlights bulbs?
Hi everybody,
Has anyone changed the factory headlights bulbs? What company shall I get? I suppose they are D2S? Thanks.
Wil
Old 07-18-11, 06:59 PM
wcntan80
wcntan80's Avatar
Just bought couple of D2S 6000k to replace the headlight bulbs of my 2008 400h. I have small hands but there is no way to fit them through. How exactly would you change those bulbs? Please help.
Old 07-19-11, 05:14 AM
iKenn
Just call me "Sprinkes"
iKenn's Avatar
I am current planning to do the same. Waiting for the car to come back from 80,000 service first. I will try my take at it and then hopefully post up results.
Old 09-01-11, 09:46 AM
JZS147btr
JZS147btr's Avatar
EDIT: I just found out that if you have a RX400h (and possibly the RX330/RX350 with HIDs), you might already have 85122+ bulbs so CHECK before buy bulbs. To check, you'll have to remove one of the bulbs and read the info on the base, it'll clearly say "85122+" if that's what you have. If your RX is already equipped with 85122+'s, there is NO BETTER BULB that'll give you more lumens. The higher Kelvin ricer bulbs will only make you LOOSE usable light output, no two ways about it.
I don't know if you know this but once you start going above 5000K (more blue), you're actually LOWERING your light output (lumens). You're wasting your money on 6000K bulbs. You'll get LESS light than your factory bulbs. Return them and get your money back if you can.
The BRIGHTEST HID D2S replacements you can buy are the Philips 85122+ (note the "+" designation....the 85122+ is PARTICULAR model, make sure you get that specific model number). HID bulbs change color over time and they generally go UP in Kelvin, therefore they loose lumens. The Philips 85122+ are specially manufactured to NOT change colors and therefore NOT loose lumens over time. If you're going to do a HID bulb upgrade, this is THE BEST WAY to go (as of 08/2011). I think the factory HID's put out around 3000 lumens, the 85122+ put out around 3400 lumens...that's a pretty good upgrade if you're looking for FUNCTIONALITY (i.e. more usable light output)
DO NOT waste your money on "no name" or "cheap" HID bulbs. THEY'RE NO NAME AND CHEAP FOR REASON! They don't last as long, they put out less light, their Kelvin rating isn't accurate, etc., etc. Also beware of FAKE name brand bulbs. You have to buy from a reputable vendor. Also, the 85122+'s can be had for a pretty good price. I would recommend buying from these guys, only $95 PER PAIR! That's only $47.50 per bulb!
http://www.theretrofitsource.com/pro...roducts_id=148
I have no relation to this company other than being a satisfied customer. I did a LOT of reading and research on this but you're more than welcome do the research yourself.
Old 09-01-11, 10:03 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Philips D2S bulbs are definitely going to among the best in quality. 4300k will give you the most light output so if you want to maintain that stock/oem look stick with 4300k. If you want more color then look into 6000k but keep in mind that the higher you go in color temperature you get more color but less usable light output.
Old 09-08-11, 06:11 AM
wcntan80
wcntan80's Avatar
Guys, really appreciate the info. Thanks a lot.
Wil
Old 10-20-11, 10:31 PM
phantomdg
phantomdg's Avatar
I changed out the bulbs on our RX400h as follows:
Front
Main beams: Garax D2S 6000K HID bulbs (yes you will need small hands and a lot of patience!)
High beams: MTEC 9005 4750K Cosmic Blue bulbs
Fog lights: MTEC 9006 4750K Cosmic Blue bulbs
Headlight parking bulbs: MTEC 168 white LED wedge bulbs
Headlight signal bulbs: Stealth 7440 amber chrome bulbs
First Row Doors
Courtesy Door Lamps: MTEC 168 white LED wedge bulbs
Rear
Taillight signal bulbs: Stealth 7440 amber chrome bulbs
License Plate bulbs: MTEC 168 white LED wedge bulbs
Bumper corner light bulbs: MTEC 168 white LED wedge bubls
Old 10-21-11, 01:41 PM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Check out these all new Original Philips 194 Blue Vision LED bulbs.
Steve
Old 10-23-11, 07:47 PM
nmmuzykam
nmmuzykam's Avatar
Hey phantomdg, could you please post a picture of your RX with the fog lights on? I am trying to decide if I should change the silverstar ultras I am currently using to something a bit bluer to match the HID low beams better. Also, do your DRLs look blue since you are using the Cosmic Blue bulbs there? I know it is hard to find bulbs that look blueish when used as DRLs due to the lower wattage...thanks for any and all help!
Old 10-24-11, 01:30 PM
mowmow
mowmow's Avatar
Changing your low beam from 4300k to 6000k will decrease your visibility on the road. I did swap out the highbeam once to PIAA Xtreme white 4300K. Now I have complete retrofit done 75W ballasts 4300k D2S HID bulbs for AFS low beam and 65W ballastswith 4300K D2S HID bulbs for bixeon and fog
Old 10-26-11, 10:34 PM
phantomdg
phantomdg's Avatar
nmmuzykam,
I just picked up our RX400h back from the dealership after having the rear spoiler as well as the front and rear bumpers repainted. I can takes pics for you. Please send me a note to my email address at dgaudinez@hotmail.com and I can email pics accordingly.
Thanks@
Old 10-26-11, 10:38 PM
phantomdg
phantomdg's Avatar
Wow! those are expensive mini-wedge bulbs! I do like the option of different temperature colors (4000K, 6000K)...
Old 10-26-11, 10:43 PM
joedaddy1
joedaddy1's Avatar
Steve
wow.. $47 for couple of wedge bulbs.. wow...
Old 10-27-11, 06:46 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Philips.... We also have the Putco high power 194 LED bulbs. Keep in mind that these bulbs are rated at roughly 100 lumens. The Putco 194 LED bulbs are made right in the USA!
ClubLexus members do receive a 15% discount by using coupon code "CLLED" upon checkout.
Steve
Old 10-28-11, 01:08 AM
RoverBoi88
RoverBoi88's Avatar
having 6k headlights put in, a LED center light to run my drl, a led wedge for center parking lights, LED the rest of the car, white domes, blue flooring, blue door puddles, and white license plating =D
Quick Reply: Has anybody changed the headlights bulbs?
