maintenance required
My 2008 400H just hit the 3,000 miles since I left the dealer as a Certified used and the Maint required light is on in the speedometer. How do I reset it, as I would rather go farther than 3,000 miles between changes.
Try this:
1. With your car OFF, place your key in the ignition and turn to "On". Do not start the car.
2. Find the odometer button and press until it reads the total odometer setting, (not the Trip A or Trip B setting).
3. Turn the key to OFF.
4. Place your finger back on the odometer button, press and hold. Then while still holding the button, turn the key back to "On" (not START).
5. Hold the odometer button in until the MAINT REQD light goes out...should take about 8-10 seconds.
Worked like a charm, Thank You very much. You know your stuff!!
Try this:
