APEXi Throttle Controller for GS450h
One of the forum vendors claims they double checked and confirmed that APEXi has a throttle controller for the GS450h. I thought throttle controllers were not compatible with the CVT. Does anyone know if this could be true?
executive matchup
if the apexi throttle controller is anything similar to tom's ETS, then the answer is no. according to tom's, there is no application for the GS450h (which is chassis code GWS191). see link below:
http://www.tomsracing.co.jp/products....php?mprID=314
trust me, if this was installable in a GS450h, i would have had it already!
edit: see link below, posts #55 & #56
https://www.clublexus.com/forums/clu...d-is350-4.html
We have plugged it into our HS250H as well as the Toyota Prius. Both made a difference in throttle response. The Apexi throttle controller works off the concept of throttle body position and does not actually do anything to the transmission. What it does is prime the throttle body moving it in a more open position so that when the pedal is pressed, it engine is ready to accelerate sooner since the air flow is increased and the throttle body plate is more open reducing the time it takes to fully open.
After testing it on our HS250H and our Prius it does work, its not as dramatic as say an ISF which has a faster shifting transmission but it does work.
executive matchup
well adamz28 can be the first to try this mod if he wants to!
Yes it does, the difference it makes i quite noticeable, its more of the throttle response that is improved instead of having that sluggish start when you hit the pedal its more immediate. I really wish you guys were local so we can do a live demo so you would see how much nicer it feels when its got that firmer response!
I feel that it is a big difference, the ISF has a more dramatic kick to it that the hybrids, but that has to do a great deal with how that transmission is built and functions.
Its a great system and WAYYYYYY more affordable than the alternatives.
i don't see how it has anything to do with transmission either. the THROTTLE controller is just that, controller the throttle with respect to the gas pedal movement. it's pretty much the same as the power button on the e9x m3. it does NOT add any power to the car, it only makes the throttle more sensitive by opening it "faster" as VIP explained.
back to application, i don't know if gsh has a different throttle setup / gas pedal sensor, but personally i doubt. if it has the same as other 3gs, then i don't see how this throttle controller won't apply.
on another note, i am interested in how much this changes the throttle response on the 3gs (on various drive train setup). on my m3 the power button is very noticeable, which does increase the fun factor of driving the car a lot
Entirely Made in Japan i believe, APEXi USA brings all their parts on containers from Japan, they dont make any parts here in the USA, they only service and warranty them. The research and development process is all done in Japan, and then the product is sent here to test fit and ensure it works. We actually helped APEXi test fit most of their throttle controllers on all of our demo vehicles.
The only thing I'm thinking it would do, is make the computer think your flooring it all the time. Which it would then respond with Emotor and V6 simultaneous, but to what amounts of power that is being put out... Still up to the programing.
http://www.youtube.com/watch?v=OEu4I...eature=related
executive matchup
you do not get more HP out of this mod, only quicker acceleration (ie: throttle response). this mod reduces the "lag" that is experienced in regular acceleration.
in order to get more HP (and to reduce your 0-60 times), you need to do hp mods like turbo, SC, NOS, engine swap. this throttle controller won't give you want you are looking for (ie: more HP).
