Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Parada Spec-X in RX400h
Old 12-12-11, 08:11 AM
robertito
robertito's Avatar
Default Parada Spec-X in RX400h
I just had these mounted, and so far, so good. The dealer inflated them to 40 psi (said it would be better for the Chicago snow), but I knocked them down to 35 psi for comfort.
Other owners, to what PSI are you inflating these tires?
Old 12-12-11, 11:51 AM
smassey321
smassey321's Avatar
I just got some tires installed last week. When I checked the pressure I was surprised that they were also at 40 PSI. I left them there as the ride was great. Keep in mind I live in FL where are roads are near perfect.
Our previous set of tires wore out on the inside and outside edges faster than the center section. In the past I was always at 33 PSI. With this set I plan to try 40 PSI to see if I can get a more even wear.
Old 01-25-12, 06:10 AM
thomas1
thomas1's Avatar
I just installed also, yep pressure was set for 37....
Old 01-30-12, 03:07 AM
digger11
digger11's Avatar
I run exactly what is on the sticker attached to the car - I think it is 34 psi.
GBHarvey
11-20-18 08:44 AM
ferix
02-20-06 04:44 AM
Morrissey
01-21-06 03:12 PM
tmhcars
09-25-02 07:50 PM
genius1512
02-23-02 02:28 PM
Quick Reply: Parada Spec-X in RX400h
