Hybrid Technology Unique topics related to the GS450H model hybrid drivetrain and other features/options found only on the GS450H. Please use the main 3GS forum for discussion about shared components with other third generation GS models.
Hybrid Transmission and (Rear diff) 90k fluid change
Old 02-04-15, 02:01 AM
  #31
gripau1
gripau1's Avatar
Originally Posted by sonnyhood
Ill send this and the image above to my lexus service centre and see what they say.
It seemed like they were actually scared to replace the transmission fluid?
Which Lexus dealer in NSW?
Lexus Sydney City should be able to do it for you.
Old 02-08-15, 06:21 PM
  #32
sonnyhood
sonnyhood's Avatar
Sutherland, its where my car was sold as new (prev owner), and all services been done there.
Old 02-16-16, 02:35 PM
  #33
Brabusx2
Brabusx2's Avatar
bumping old thread, looking to do this as well, the Camry video seems too much.. is it just drain and fill or do i really need to take whole thing apart?
Old 06-24-16, 02:02 PM
  #34
carcrazy52
carcrazy52's Avatar
Im wondering the same... heard you dont change trans fluid at since its considered lifetime fluid?
Old 06-07-17, 10:49 AM
  #35
samsonn25
samsonn25's Avatar
Lets see what they mean by "lifetime fluid" as I have 176k on my 07 model so far. I have seen other GS450h cars go over 210k so far
Old 12-27-17, 04:07 AM
  #36
HaerdenC
HaerdenC's Avatar
it can be perfectly done at home with a jack stand, it needs indeed a lift in order to fully empty, after that make sure you use only the original toyota/lexus CVT oil, even same grade of other brands will lead to problems. I replace mine every 45.000 miles just to be sure everything is fine, I do it together with the diff. The diff is identical to any other rwd car, just need a long tube to fill as the fillerhole is located on a very unpleasant location
There is a metal film filter on the inside of the cvt gearbox and it doesn't need replacement it's a lifetime filter, same with the fuel filter that is in the fuel tank it's magnetized so metal partials just glue to it. Life span of the cvt gearbox is far longer then the lifetime of your car 500.000 miles or more without any issues :-)
Wood3000 (05-23-21)
Old 12-28-17, 04:21 AM
  #37
Ngin
Ngin's Avatar
Lets see if this shows up.
I attached the service and repair article on CVT
Old 12-28-17, 04:35 AM
  #38
Ngin
Ngin's Avatar
One more time, lets see
Attached Thumbnails Hybrid Transmission and (Rear diff) 90k fluid change-20171228_072308-1-.jpg   Hybrid Transmission and (Rear diff) 90k fluid change-20171228_072333-1-.jpg   Hybrid Transmission and (Rear diff) 90k fluid change-20171228_072358-1-.jpg   Hybrid Transmission and (Rear diff) 90k fluid change-20171228_072414-1-.jpg   Hybrid Transmission and (Rear diff) 90k fluid change-20171228_072703-1-.jpg
The following 2 users liked this post by Ngin:
dkotanto (12-14-20), Wood3000 (05-23-21)
Old 05-30-18, 05:39 PM
  #39
dc71
dc71's Avatar
Default Issue with transmission ATF change
Hi guys new to this forum
I have a problem failed to locate the plug for
filling in lexus Gs450h 2006 model
mine just has two plugs one below and above on filling side if some one could help with that
my car has this transmission ( pic from eBay )
usually should have WS stamped on one of it but not on mine ,any help appreciated thanks
Which one to use to fill the transmission
Lexus Gs450h transmission 2006 model Two filling bolts ( not marked ws )
Gs450h transmission
Originally Posted by bigblack06
Ok, random but is there a way to change the transmission fluid on the GS 450h and has anyone done it yet. I was reading about someone on toyota nation who changed there toyota Camry hybrid. I understand the camry is different from the GS but was wondering if it can be done and if anyone has tried this yet. Thanks in advance.
Old 07-07-18, 11:17 PM
  #40
Swegerian1
Swegerian1's Avatar
Default Hole #2
dc71. I’d fill hole #2
Old 05-23-21, 01:46 PM
  #41
Wood3000
Wood3000's Avatar
You are nuts to suggest "You pour 75-90 in the engine and you will get a good visual on compression physics."
chromedome
Hybrid Technology
12-26-23 06:46 PM
rajenmodi
HS 250h Model (2010-2012)
01-07-18 08:34 AM
sktn77a
RX - 1st Gen (1999-2003)
02-11-09 10:23 AM
Stage3
03-02-06 12:54 PM
Quick Reply: Hybrid Transmission and (Rear diff) 90k fluid change
