Antifreeze
What level of coolant antifreeze is standard - I am in Chamonix at minus 12 degrees centigrade - what level of coolant antifreeze will there be as normal?
You should check with your local dealer. It's not a world wide standard but based on geographical areas. Usually it's plenty to handle what ever temps are normal in your area.
I do not do anything when seasons change unless make sure the "gasket" alongside the doors are a bit sprayed with adequate protection to avoid freezing of them and damage under specific weather conditions (rain/humidity and very cold temperature in a short period of time; like when you go to ski, rainy in the valley and frozen at the ski station...).
Otherwise do not do anything else for cold conditions except pouring antifreeze (-25°C) water in the tank for wipers (and try to have this tank always full).
As Jim2 said, antifreeze is designed to work in a 50/50 water solution. Any more and you can get gelling and reduced freeze protection but also less high temp protection. If it was 60/40 each way that would not be bad but that is where I would start to think about balancing it out.
They also sell premixed stuff to add to the resevoir if that is all you need.
b2884987
Maintenance
03-23-18 04:10 AM
