Force Charge,Screen Question,Double Locking
What up guys...
I was reading about force charging the battery...if i remember correctly turn the car on,put it in drive press the brake and the accelerator at the same time....?Now i assume this is while actally driving the car/when car is in motion(something like on my turboed cars when you are in motion you press the brake just enough to slow down the car a bit and then press the accelerator pedal enough to build up boost....correct?
Also i was curious if anyone can explain then demographic screen that shows the way you are driving the car and how many kw you have regenerated(like in this thread post #6)
https://www.clublexus.com/forums/hyb...tely-full.html
Now,I see that it actually shows the best mileage on some of the screens,on mine is always zeo.Is there a way to turn this on?Also what do the graps tell you?For instance on this screen post #6 on the link above....
And finally...
I have the double locking feature with the factory alarm.
Can anyone explain the way the double locking works?I can actually hear it lock the door twice.Are there 2 different locks in the doors?Like on some Security Home doors?
Thanx Guys.
And finally...
Thanx Guys.
