Hybrid Technology Unique topics related to the ES300h model hybrid drivetrain and other features/options found only on the ES300h. Please use the main 6ES forum for discussion about shared components with other sixth generation ES models.
Old 01-07-15, 12:26 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
ES300h Gas mileage
Old 01-01-18, 02:24 AM
  #526
chromedome
chromedome's Avatar
On another note, I've been riding around in an X5 plug-in hybrid recently and the gas mileage has to be seen to be believed. As in it's astonishingly bad.
Sure, it weighs 1300 lbs more than the ES300h, with most of the extra weight coming from the big battery pack. The same kind of careful driving that got me 45 mpg on the ES couldn't crack 25 mpg on the X5 and I couldn't hit the rated 15 miles on purely electric driving. Toyota was right to focus on hybrids and battery electric vehicles - plug-in hybrids are a poor compromise that only make sense on official test cycles, not in the real world.
jollick (01-01-18)
Old 02-16-18, 06:22 PM
  #527
Donresnick
Donresnick's Avatar
Angry 2017 ES300h Terrible Mileage
I bought my 2017 ES300h in Oct 2017. After about 4 months I am getting 22.5 MPG in-town driving. I’ve brought the car into service three times, and they have made a few adjustments including rebooting. But the mileage never varies.
Here are the factors I can think of: it’s been a fairly cold Connecticut winter, but it was no different in the warm fall. A lot of my driving around town is about 15 to 20 minute trips. I drive with a very light foot, trying to bump up the mileage, but the car never goes into EV until I’ve driven for over 10 minutes, and then only sparingly. At a traffic light it only goes into EV about half the time unless I think to press the EV button. It’s not clear to me why it does sometimes and not others. Driving, it only goes into EV sometimes when coasting downhill, or creeping along at 10 MPH or less, and then only sometimes.
I’ve noticed that after driving for about an hour on the highway, the car starts using EV more often on city streets. The engine, and maybe battery, seems to need to be *very* warm before EV mode is used the way I think it should. But still not enough to bump up the mileage.
I know my driving style (short trips) is the worst for mileage, but 22 seems completely unacceptable for a hybrid. Anyone have thoughts?
Old 02-16-18, 09:50 PM
  #528
chromedome
chromedome's Avatar
Default Ethanol
How cold does it get over there? Hybrids get worse mileage in winter because the engine has to run more often to warm up emissions control devices and for cabin heat. You could try turning off cabin heat and see if the engine turns on less often.
I get 30-35 mpg when it's below zero C and I'm driving in slow traffic. Gas here is 92 octane with no ethanol. In warmer weather I can get close to 50 mpg under the same traffic conditions. I wouldn't worry about the EV light turning on, drive the car as efficiently as you can and enjoy the ride.
Old 02-17-18, 05:03 AM
  #529
TechNut
TechNut's Avatar
I appreciate Chromedome’s perspective, but with the gas blends in North America, especially the northern states, you won’t see the mileage figures he is getting. Most NA fuels now contain Ethanol which harm the mileage, plus our octane figures are lower. However, with that said I still think you should see better mileage.
Keep in mind, there is no magic to a hybrid and you are correct that short cold weather trips are the worst possible scenario for a hybrid. The gas engine has to completely heat up to normal operating temps before it will transition to electric. This is to run the heater (which requires hot water in the heater core) and for safety of your gas engine as you don’t want to strain a cold engine. Now with that said, we have a similar driving style, mostly 15 to 20 minute trips. Our average temp over this winter has probably been 35 to 45 degrees F and our worst tank was just over 33. Last winter when our weather was much colder I don’t believe we dropped below 32. Last winter our NX 300h, which has the same drivetrain as the ES 300h (except it has an electric motor for the rear wheels) became our goto vehicle when the snow was too deep for the ES and the temps dropped below zero. Our worst tank even in those conditions with that heavier vehicle and winter fuel blends was just shy of 30 MPG.
The ES is our third hybrid, and the NX is our fourth. So I am very familiar with their benefits and limitations. In my opinion, there is definitely something wrong with your car. Even in the worst possible conditions, you should be getting 8 to 10 mpg better. In the best conditions (summer with gentle driving in eco mode) it isn’t unusual to get 37 mpg. I have seen 40 MPG but only once. I have seen 38 MPG several times in the 16K miles driven in our ES.
While it shouldn’t account for the huge mileage differences you are seeing, are you sure you are driving in “eco” mode. From you description of the driving characteristics, it almost sounds like the car is behaving as though it is in “Sport” mode. Sport mode is definitely more fun but it has a detrimental effect if you are trying to nurse the best mileage from your car.
Old 02-17-18, 05:28 AM
  #530
TechNut
TechNut's Avatar
As if my long-winded post above wasn’t enough, another thought occurs to me. It generally only takes about five to eight minutes before our car has warmed up enough that the gas engine will begin cycling off and on. This of course is dependent on ambient temps and the driving mode selected (eco/normal/sport), speed, etc. In extreme cold weather it doesn’t cycle off very often, but you will still see mileage benefits due to the electric motor which is always active if the batteries have a charge.
Again, in my opinion, there is definitely something wrong with your car and the dealer likely knows it. I just can’t imagine how I could possibly drive, even aggressively in Sport mode and get such poor mileage.
Old 02-17-18, 05:52 AM
  #531
jollick
jollick's Avatar
Just to be sure, you are averaging a tank full of gas at a time using a calculator, not going by the car's display, correct?
Old 02-17-18, 06:20 AM
  #532
chromedome
chromedome's Avatar
If you really want to get technical, I'd suggest getting an OBD Bluetooth dongle and using Torque. When the car first powers up, monitor the engine coolant temperature. The engine should go from cold to 40C before shutting off if there's no load. The next phase is for the engine coolant to hit 75C, once it hits that the car should enter EV mode more frequently. If your car isn't doing all this, then there could be a problem.
More info here: http://techno-fandom.org/~hobbit/cars/five-stages.txt
It's a Prius system primer, our cars are nothing more than large Priuses with slightly larger battery packs
Any engine or hybrid system faults should be logged by the ECU and these would be visible to the dealer. I'd be surprised if they couldn't find a problem with the car.
Old 02-17-18, 09:55 AM
  #533
Nguyen087
Nguyen087's Avatar
You definitely need to be checking with the odometer and calculator on gas refill to make sure the numbers are correct. 22.5 mpg is totally unacceptable for an ES300h unless you are in sport mode all the time and have really unusual driving style. That would be normal for a ES350 but not the hybrid. I would bring it back to the dealer every week until it was resolved.
Are you sure you are not looking at the average MPH and not MPG? That is also one of the screens displayed on the dash which would make since to be around 22-23 mph.
Old 02-17-18, 04:42 PM
  #534
Donresnick
Donresnick's Avatar
Thanks all.
The 22.5 MPG is from two half tank fill ups and computing exact actual mileage each time. Both times the display was saying 24.5. In between the two, the shop foreman at Lexus hooked the car up to a computer, rebooted the car and made some adjustments. Don’t know what he actually adjusted, but it made no difference. And now that I’m writing this, I realize that the weather made no difference either. The first time was that very cold spell in January (teens), and the second time was last week where it was at least 20 degrees warmer: mid-30’s.
So, don’t know what the next step is. This car is not getting much better mileage than my 2010 ES350 — about two mpg better. Btw, I drive in normal mode, not sport or ECO. I really don’t like ECO.
Old 02-17-18, 10:40 PM
  #535
jgscott
jgscott's Avatar
Received 1,349 Likes on 1,070 Posts
If you can, I would possibly reset the MPG calculator and let someone else drive the car a day or two, if you have that option, and see what they get.
Old 02-19-18, 11:52 AM
  #536
video272
video272's Avatar
Thumbs up Mileage
I have a loaded 2016 ES 300H. I generally get 32-36 mpg on short trips and have gotten 50 mpg on a 2 hours highway trips at 60 -65 mph. Have been totally satisfied and this is the 3rd Lexus hybrid I have leased. All have gotten mileage as advertised.
Old 02-28-18, 05:16 PM
  #537
Donresnick
Donresnick's Avatar
Again, thanks all.
I tried an an experiment this past Saturday, and drove a mixed environment for about two hours: Fifteen minutes of highway driving, mostly to warm up the engine, followed by fifteen minutes of city driving, then an hour of country roads, and finally another half hour of city streets to complete a loop. The display on my car showed 42 MPG!
Since then I’ve gone back to my normal schedule of ten to fifteen minute rides (office, grocery, gym, etc.). The mileage is dropping, now down to 33 MPG in three days.
So it seems that the car is capable of hybrid performance but will barely use battery on these short trips. Does anyone know if there is a computer adjustment to address this?
Old 02-28-18, 06:16 PM
  #538
GES
GES's Avatar
Again, thanks all.
Short trips are not good for fuel efficiency in the hybrid. With repeated 10-15 minutes trips, the engine has to run constantly half of the trip to get to the optimum operating temperature. Therefore you will not get the 40+ mpg advertised. Mid to low 30s is about right. Only when you drive 30 minutes plus at reasonable speed you will get the 40mpg. I don't think there is a way around this with the current hybrid system Toyota uses.
Old 02-28-18, 06:50 PM
  #539
chromedome
chromedome's Avatar
Hybrids are conventional cars with electric motors tacked on, not the other way around. The engine runs most of the time to keep itself and the emissions control systems warm. Short trips are bad for mileage because the engine doesn't have a chance to warm up and it also has to run as a generator for the electric motor. Cold weather makes this worse because the engine has to run even longer to get warm.
Plug-in hybrids or battery electric vehicles are the best for short range trips, their battery packs can supply enough power to run on electric-only mode for the whole trip.
That said, I've hit 50 mpg on a short commute in warm weather and with a good stretch of green lights. Lifting off the throttle and then gently getting back on it in Eco mode helps activate EV mode at low speeds. Have a look at pulse and glide techniques if you want to hit high MPGs.
Old 03-03-18, 08:29 PM
  #540
mrBillFL
mrBillFL's Avatar
I have a 2013 300h, and have gotten 39 mpg on a few tanks when I tried, but average around 35 and drive with a heavy foot on I-95.
in my experience:
The ideal road is 45 mph limit, you get up to speed say 43 then and a big lift off the gas, and feather the throttle. I can 'activate' the EV mode in this way,
Once EV mode is engaged, it will stay there if the throttle stays below half. once the engine is warm.
I also reprogrammed my dash to always show the throttle position, vs rpms. on the left dial. I also put the driver mode on the mpg (the one that show tire pressure), so even on a 65mph road, I can see 40mpg on the dash, if I feather the throttle.
33 mpg isn't unreasonable, but you can probably boost that a few points by learning how to engage and say in EV mode.
22 mpg,doesn't sound right to me. stuck brake?
Quick Reply: ES300h Gas mileage
