very bumpy ride....
My RX has a very bumpy ride. I feel every little bump on the road and there is a constant vibration, that keeps the change in the center console making noise, and it is driving me a bit crazy...
The tire pressure is okay and the alignment is fine as well. I will take it in for a check up soon but I wanted to see if anyone else has this issue.
TIA
TIA
might need a wheel balance. wheels can warp for a variety of reasons (banged against a curb etc) and the slightest imbalance can translate into massive vibratiion (aswell as uneven tire wear, which can lead to premature failure). Any garage should be able to check wheel balances
Nope, mine is just fine. I am riding on 18" wheels and winter tires for the season, though. Wasn't a problem on stock 19s.
Do the vibrations go away at certain speed? A bent rim will vibrate at a specific range, e.g. 60 MPH.
If you get your tires balanced, they will be able to tell you if your wheel is bent right way, even if it balances.
Many places will tell you that bent wheels need to be replaced, but they can actually be repaired. I had 2 wheels on my IS straightened-out. It is a fairly simple process.
Ride is OK in my 2013 450h. Bad streets are a little bumpy but otherwise car is fine. It rides rougher than my dad's Cadillac but that car handles like a boat! I have 19 inch wheels. OEM Bridgestone tires. Maybe you have some problem with suspension? The problem is what you feel is bumpy may feel normal to others. Maybe go to dealer and test drive another RX?
sarah
Wheels, Tires & Brakes Forum
07-22-15 11:41 AM
