Electric motor still pulling with brake pedal pressed
Aha, I see, thanks for the clarification.
When assembled, the switch must be quite hidden above the pedal support, because I looked carefully, and didn't see it.
Anyway, just this diagram alone shows that what driver125 experienced must have been a coincidence.
It's self-evident that the brake light are driven by their specific switch, while the hybrid system (which obviously needs to sense the pedal position through its whole excursion) must be driven by the stroke sensor.
Hi,
Since this isnt a traditional engine/transmission setup, if u had the gas pedal pressed on hard right before braking, the the engine would continue to rev at high rpm to level off with the cvt and pull the car while you try to brake. This gives that "pulling" sensation and is normal. If thats not the case, then I suggest you have it checked out because it might be a sensor problem.
Second, (not sure at what speeds, but seems to happen moreso when I'm going faster or accelerating like you mentioned above) when I hit the brakes there is a very noticeable stutter when what feels like going from regen to friction where it seemingly losses braking friction or grabbing power. Not sure what this is, but it is only for a split second. But split seconds matter when you are driving and trying to stop.
guxu
RX - 4th Gen (2016-2022)
19
06-03-21 05:23 PM
