Adding tow hitch?
Just installed the Curt hitch. Pretty easy. I did notice on the driver side the a plug like I see in the videos. I guess even without the tow prep package they have it wired.
i assume then all I need is that adapter wire.
I assume all I need is this (though it says for 2012 and mine is 2013).
Tow Ready 118252 Connector Assembly
http://www.etrailer.com/Custom-Fit-V...leid=201214985
All of 450h get that plug. But when you connect the harness, you will find it dead.
Trust me, I found out the hard way. If you look under the hood, you will see 2 towing fuses missing. Replacing them won't do a thing. There's a plug where the controller goes, which is behind the right tail light. Took me a few hours to locate it. I had the whole left side disassembled trying to trace wires from the plug you mentioned. It ended up on the right side.
You can certainly buy that connector. That's what I got from Curt. Ended up wiring a generic towing lights controller I already had from a previous car. Having all of wires accessible in a single plug made it a walk in the park.
I initially purchased a Reese hitch for my 2013 Lexus RX350. It mounted up okay but did not have sufficient clearance between the exhaust pipe and the hitch. I had to remove it and purchase a Curt hitch which fit properly and had plenty of clearance between the exhaust tailpipe and the hitch.
Beware!!!!!!!
I purchased the electrical quick connect from E-Trailer and it plugged in with no issued. Extremely happy with installation now that I have a Curt hitch installed.
Beware!!!!!!!
The plug I saw was also connected to some black box just above it -- I had thought it was a controller. The remaining wires went into the deck.
So I assume it is not connected anywhere on the right side (near tail light). And I need some controller to wire to it and the tail light (there is a plug?)? Then I can also buy that adapter.
Sorry but I am confused...
Nope. If you weren't charged for the towing prep, you don't have it.
i assume yours came with the Tow Prep package based on the other post (i.e., that the plug would be dead).
Beware!!!!!!!
Beware!!!!!!!
I checked by fuse box. The #44 fuse (30 amp) for towing is present.
Can I then assume that plug in the back under the left side is live?
(#43 Towing batt fuse is empty as well as #45 Filter.
