Oil change on the ES300H
#31
I don't believe that Toyota would recommend a 10k oil change if it could even remotely be damaging to their engines or create excessive wear and tear. I'm quite sure that Toyota wishes to maintain their reputation for quality vehicles and happy drivers. Lesz states a good point: If BMW, Audi, and Benz can do 15k changes using full synthetic oil, then Lexus can as well. I changed mine the other day and it was so clean that I had to look twice to read the dipstick. The oil was 10 months old...
BMW Longlife-04 (BMW LL-04)Special BMW approval for fully synthetic long-life oil. Viscosities are SAE 0W-30, 0W-40, 5W-30 and 5W-40. Usually required for BMWs equipped with a diesel particulate filter (DPF). Can also be used where a BMW Longlife-98 or BMW Longlife-01 oil is recommended.BMW Longlife-12 (BMW LL-12)Special motor oil for certain approved gasoline engines and the following diesel engines only: Nx7K1, Nx7U1, Nx7O1 from model year 2013. Not suitable for engines with 2 or 3 turbos.BMW Longlife-14+ (BMW LL-14+)Special motor oil for the following gasoline engines only: N20, Bx8 from model year 2014. Not allowed for diesel engines.
#32
#34
It is spec'd to be able to maintain adequate lubrication and detergency for 15K oil changes. Look it up.
#36
When Toyota was recommending a 5000 mile oil change interval for its 3.5 liter V6, it was with the use of conventional motor oil. As far as I know, since recommending the use of full synthetic oil, the recommended oil change interval for this engine has been 10,000 miles. With regard to "pushing the limits", my guess would be that Toyota/Lexus is actually being at least somewhat conservative. Other manufacturers, like BMW, are now using a 15,000 mile oil change interval with full synthetic oil, and I can't imagine that their production tolerances are significantly better than those of Toyota/Lexus or that their recommended oil is that much superior to that of Toyota/Lexus to allow for oil change intervals 50% greater than that of Toyota/Lexus.
The maintenance required light goes on at 5000 mile intervals, but the recommended maintenance at the intermediate intervals calls only for tire rotations and inspections.
#37
Had a 07 GS450h using conventional oil going 7-10k oill change intervals, ran it up to 263k with no problems.
Currently 13' ES300h has 228k miles now and using regular synthetic mixed with extended and going 13-18k between changes.
tomscot2 (01-09-23)
kambam3627
04-13-18 03:09 PM
ToyotaLexus
Maintenance
02-17-09 01:28 PM
