how to replace 2013 es300h cabin air filter?
Hi All, would anyone please share with me on how to replace the cabin air filter in my 2013 es300h ! Thanks in advance...!!!
From memory, you remove the plastic shelf in the glove box, remove the rear access door of the glove box, remove the access door to the filter, and pull out the filter. Reverse to install. It takes about 10 minutes the first time.
The dealer will charge you anywhere around $50 for a similar filter had on Amazon for $15. This is one of the easiest maintenance you can do, next to washing your car.
I read somewhere that the air system should be set to recirculate before removing and replacing the in cabin air filter but maybe that applied to previous models only? I’m wondering if that also applies to the 2013 through 2018 models.
