Running Out of Gas
Running Out of Gas
This may be a stupid question, but apart from a short test drive I have no experience with hybrid cars. How does the NX behave when it runs out of gas? Will it stop right there? Or will it continue to run on electric power alone?
OK, I couldn't find any Lexus-specific info, but I guess the system must be more or less the same as the one used in Toyotas. As I understand, with a hybrid Toyota you can still limp a few miles in electric mode until the batteries get to an unsafely low level and the car shuts down completely. I understand the car will shut down when you still have enough power to restart, though apparently you can force it beyond that point if you're determined enough. But it seems that if the batteries get completely drained the car won't start again and will have to be recharged using a special tool that only official Toyota dealers have. That sounds scary. Better stop right there and add some gas.
This would only happen if you have the car stored and it wasnt used for a long enough time that the traction batter would be drained that low.
Or if you were driving and it ran out of gas, in that scenario the car would run out of gas then you have a little juice to go a short distance, and car would shut down but you still have plenty of juice left in traction battery after you refill with gas to kick start the gas engine to begin to recharge the traction battery.
The dealer told me when i picked up my car, make sure i don't deplete the gas or otherwise it will mess up the hybrid system and expensive to repair.
LexFather
04-24-09 01:13 AM
