Any Issue(s) on 4th Gen RX450h ?
Upon completion of the dash, we reached an agreement, for what's it worth, that if in my routine cleaning of the dash with the chemicals I routinely use the blemish shows up again, they would replace the dash. Not an option I relish, but that blemish is too much to bear on a new and expensive car.
I drove over around a quiet parking lot in EV mode yesterday and did not hear either sound.
Ericsan13
Opened ticket with Lexus Customer Care about the brake click/squawk noise heard during lower speed braking. Took my 450H to dealer for Lexus Factory Rep (LFR) to inspect. LFR test drove car and heard the click/squawk noises. LFR recorded the noise to include in his report back to Lexus Factory staff. Service manager said there may or may not be a fix. The good thing is that Lexus is aware of the issue. Dealer did not have another 450H on the lot for me to drive. So i do not know if other 450Hs have the same brake click/squawk noises. Still enjoy driving the 450H. So....it is a wait and see for me. Will keep you posted.
Ericsan13
To you having owned a 3. gen Rx:
My 2011 RX450h was very smooth when driving in parking lots and traffic - when barely moving. You could barely hear the engine start, and newer hear it stop. In my 2017 RX450h, the engine starts With a small shiver in the car, it revs higher, and it feels like the car is making a small jump forward. When it stops, it does With a short vibration - not much, but quite different than in the 3. gen. Not so smooth as I would expect in a Lexus.
Is this my car - or is this typcal for 4. gen 450h?
Yes, my 450h does the same thing. Plus the brake noise. Lexus's quality is worse than toyota. Last Lexus.
Lexus has been good to me and yet I have ventured to other brands like Range Rover, Mercedes and Porsche and it is always nice to go back to the Lexus.
I had the RX450h F-sport for a month now with 700 miles. Just love this car with all the technology especially in safety...Brake by itself! Once backing up from garage and got a near miss to the trash can, thanks to the self brake system. I used to own the first generation LX450 and it lasted till 180,000 miles(retired). The only problem I had is the rear trunk sensor at the emblem which does not work to hand waving most of the time. Do you guys have the same problem? I know there was a recall back a few months ago for the ECU of the trunk opener, so wondering if it is related to that ECU. I got the car in April 1st, dealer should have fixed the recall, right??
I do hear a clunk noise when applying the break. It is soft, so I only hear it when radio is off and driving at low speeds in parking lots. Seems worse when cold and car just started.
As as far as when the engine turns on, it varies. Sometimes it is smooth, other times it shudders. A couple of times while at a light, the engine came on at higher RPMs than usual and the car lurched forward. This only happened in cold days.
My engine always turns on when the battery indicator shows 2-3 bars. It never lets it get below 2 bars.
I actually just put a knuckle from one finger on the top of the emblem. I feel stupid hovering my hand for no reason.
yardbird88 (05-05-17)
Thanks, I tried it again last night and yes,it only work by holding your hand a few seconds(way too long) near the emblem. The manual lies by saying waving your hand up & down. It's a useless function. Lexus needs to fix the sensitivity.
Don't quote me but I believe there is a way for you to customize the sensor sensitivity. I doubt you can change the length of time needed though.
