Premium gas for 2016 RX 450h?
#61
I did numerous tests . Going on a road trip and heavy city driving . Heavy foot, light foot , cruise etc.. the regular performed better. It's personal preference for me and i will continue using regular as there is no difference in performance . i know people like to grill regular gas users here but please don't hesitate especially if gas prices are high. Regular is fine. But when gas is cheap sometimes il use the premium , still don't notice a change in performance. Someone will say well in the long run your car will suffer , well let's see about that. It's a lexus it's supposed to be reliable right. My buddy who works at lexus checked out the car and he said everything was fine and recommended whatever gas you feel like. If it gives you peace of mind to get premium im for it. Don't hesitate using regular either because it's SOS
They tested four cars - Honda CR-V, BMW M5, Ford F-150, Dodge Charger. The Honda only recommends 87 so premium did nothing - no surprise there. With the other three where the recommended octane is 93, dropping to 87 (91 on the M5) basically reduced hp. The M5 got better mpg with 91 (by .7 mpg), the Ford and Dodge got slightly better with 93 (.6 and .3 mpg respectively). The 0-60 times were all quicker with 93, as were the quarter mile times. Makes sense that would follow with the hp difference.
So their bottom line answer to the question "does premium matter", they concluded "it depends".
They did offer a note on knocking that I found helpful. They did say that consistent knocking will damage the engine over the long term. However periodic knocking will not. Once these engines detect knocking, they back down immediately. So modern engines running on 87 should not have any long term issues because the engine isn't actually knocking. The cars detect and adjust immediately. They ended with this quote from Stephen Russ, senior technical leader for gas engines at Ford, "[knocking] is usually detected and addressed within one or two combustion cycles and poses no threat to the engine."
It would seem the only end result is there is less hp available. And since a hybrid is supplemented by the electric engine anyway, I can see why the 450h might have zero "butt feel" difference in performance. Mpg difference could easily "depend" based on how and where we drive. Might explain why many of us get different results.
#62
Interestingly enough the July Car and Driver just came out and they have an article on this exact topic. Just came out so I can't find a link just yet.
So their bottom line answer to the question "does premium matter", they concluded "it depends".![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#63
gadgetman1 (06-24-19)
#64
So I kind-of agree now that folks should go with the fuel they like for their own personal reasons.
Geekteach (12-18-19)
#65
If you get bored reading this thread, you can go to the hybrid section and read about the same worries. I use regular from Costco, when in town and the lowest grade on road trips. I have been doing this for 30 years of road trips and never had an issue. 2018 450HL
ravenuer (12-15-19)
#66
I'll offer the same opinion I did in the hybrid thread.
Bottom line is it does not matter but your results may vary.
Several months ago Car and Driver did a test with four vehicles and ran dyno and acceleration tests using regular and premium, all in vehicles recommending premium. In all cases, hp dropped using regular, but not so much that it would be noticeable to the driver. IIRC like 4-8 hp. MPG impact varied - three got worse, one got better. But by tiny fractions - tenths, < 1 mpg. They concluded that in real world conditions, neither of these things would likely be noticed by the driver.
They also made the point that modern engines are built to react to octane levels within a couple cycles. The only thing that causes engine damage is persistent knocking, these engines won't knock very long, if at all. Basically safe. They adjust immediately.
So the moral of that story was use what works for you, and understand that your results may differ from others depending on how and where you drive. In my 450h, I notice a consistent 1 - 1.5 mpg drop using regular. But drives exactly the same.
#67
I have a late year 2016 RX 450h. I started out using regular gas for several months before switching to premium for 2 months (to determine if premium gas was worth the extra cost). I saw no difference at all in performance or gas mileage, so I switched back to regular. After 3 years and 4 months, my RX still performs like it did when I first bought it. I see absolutely no justification for paying up to 40 cents a gallon more for premium gasoline. Perhaps it might make a difference in cold weather or high altitude locations but, here on the central coast of California, it definitely doesn't.
gadgetman1 (12-18-19)
#68
#69
I was drawn to Lexus for replacement of my 2008 Highlander Limited because I wanted a more luxurious vehicle which would get somewhat better gas mileage and help the environment at the same time. So I have been exploring the RX 450h (or RX 450hl). In fact, my wife has a 2020 Toyota RAV4 Limited Hybrid that she is happy with (40+ mpg), albeit the number of recalls that the car has had.
However, I’m very confused about the actual fuel savings between the RX 350 and RX 450h. Because the RX 450 requires premium gasoline, it would cost somewhat more at the pump.
Assuming that I drive a RX 450 15,000 miles per year, at an average of 30 mpg, and at $2.97 per gallon (for 93 octane at Exxon), the fuel cost would be $1,485. But for the same distance on the RX 350, which can run on 87 octane ($2.19 per gallon), at an average of 23 mpg, the annual cost would actually be lower, at $1,428.
I thought I was missing something. So I asked the dealer and the response was: 1. You can try 87 octane in the hybrid and see if you lose MPG after getting a baseline from a few tanks of premium. 2. Look at the other 3 benefits of the hybrid (less pollution, quieter, front brakes last longer). If in the end your math doesn’t make sense for the hybrid, please take advantage of an RX350 that uses 87 octane.
Thoughts, anyone? Please don't flame me if I appear to committing sacrilege.
#70
#71
There are many threads here about wjhether you need premium gas. You will find that there are many people who do not use the higher grade, and I am one of them. I addition there are many threads on savings that are not related to MPG and the fact that hybrids do save money over non hybrids. MPG savings are just nickles and dimes and the real savings are in the other maintenance items. Enjoy the reading.
#72
#73
I used to have the '16 RX350 - I was lucky to get the equivalent of 18 mpg on my usual commute. My previous vehicles were all sedans (and manuals), so they were closer to 23 mpg for comparison. Got tired of having to fill up every 5-6 days (this was well before Covid), so traded it in for the '18 RX450h. Never regretted it one bit. I'm still getting well north of 30 mpg; plus all the other benefits of the Hybrid over the regular RX.
As for the type of gas to use - it all depends on how sensitive you are to the driving 'feel'. Lots of people don't notice a difference. For myself, I can feel the difference in between brands of gas at the same octane, let alone different octanes; so I stick with Shell 91, which has given me the smoothest driving experience (and best mileage).
#74
Just curious; what mileage are you getting with your Highlander? Forget EPA numbers; the RX350 should get pretty close numbers to your current Highlander unless you do a lot of highway cruising. The rated 23 mpg combined is very optimistic for the 350; while 30 mpg is quite achievable for the 450h (especially if you're used to driving a hybrid like the RAV4).
#75
So you're able to use 89 octane to achieve this performance even though minimum recommended octane is 91? As an aside, I can't even find 91 octane at any of the branded gas stations in my area.
