RX450h does not start
If they are still in the process of reconstructing everything, I think you'll just have to wait until they are finished to see if their R&R process resolved the issue. If not, you now potentially have two shops who could be the culprit, and they will more than likely start the finger-pointing game, each saying it's the other's fault. Then again, if it starts once they are finished, you can chalk it up to having been a connection problem in a harness which they got resolved.
You need to connect OBDII reader and get the error code(s). Carista can do this for you rather easily.
I suggest you find some competent people to look at this. Fixing hybrids is no walk in the park.
OP, did you ever get this resolved?
It appears there is a reason why you were not able to read the codes.
I use Carista app and the scanner, which reads individual ECU codes, while a generic scanner does not.
That's why I was able to extract the exact error when my Hybrid developed a wiring issue.
If G seonsor is triggered air bag would pop. I don't think it was such a big impact. Hybrid has high voltage and and low voltage control circuits, w/o specific trained knowledge it is not
easy to tackle the problem. Do you get green ready indicator on the dash? Tried to jump start just in case your 12V battery is low in charge. I think dealers have special diagnostic
tool to TS hybrid system. I also drive '15 RX450h. I hope it works OK when weather here gets COLD(like -30C)
The confusion part is that "start" can be the ICE running on gas. For that you need to have operational traction battery [If your RX450 has been sitting for few weeks] the traction battery may need a boost from the dealer.
Salim
Brabusx2
12-04-14 02:58 AM
