Automatic sunroof opener not working
My sunroof no longer opens all the way with one touch of the button. It also can now be operated with the tilt switch. I don't remember it working that way before there was a power disconnect.
SJM (06-03-24)
Kind of the same topic, I just noticed that my sun/moonroof is NOT responding at all to the buttons (as if I had a blown fuse). I looked in the manual and it said it was the driver dash fuse box fuse #14 @ 30A. I pulled it out and it checked out ok. I also disconnected the battery for about 30 sec. and reconnected. Still no response to The buttons. Any suggestions? I'm pretty capable of exicuting challenging tasks. Thank you.
no fuse blown. I have an LS430 2001.
I have a 2017 rx 450h. The sunroof is no longer opening fully. It opens about half ways but the rear portion of the sunroof doesn’t raise or move at all. The process just stalls here and pressing any other button directions just causes it to close. The tilt adjust seems ok.
Basically the front half of the sunroof seems to function fine, the rear half and the divider between the two pieces of glass doesn’t move at all. Resetting it by holding button made it cycle through a process but it didn’t fix the issue
SJM (06-03-24)
masboy
GX - 1st Gen (2003-2009)
03-16-15 02:56 PM
