Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
My Lexus 450h Warning "Check Hybrid System"
Old 09-20-23, 09:17 PM
  #76
david7756
4th Gear
david7756's Avatar
Originally Posted by david7756
On my 2011 RX450h, I started seeing, intermittently, the "Check Hybrid System" warning light about a month ago. Error code PA0AA6-526. . . .Last week, for the first and only time. lots of warning lights appeared on trying to start the car--Check Hybrid System, Brake System, Power Steering System, Check Engine, and maybe some others. The car started normally (A/C running normally, etc.), but would not move in forward or reverse. No power steering, and brakes spongy. Brand new Lexus 12v battery. had it towed to the dealer. Same error code. But this morning when I picked the car up at the dealer, it started and ran normally. Any ideas??
The most likely culprits in my guesswork are: (1) air conditioning condensation leading to moisture getting into high voltage electrical plugs or wiring, or (2) high pressure under-carriage car wash, which occurred the day before the car would not start for a while. Worst case (even worse than needing a new hybrid battery) would be ruined wiring inside the transaxle assembly. But if it were that worst case scenario, then why did the system reset itself and clear the error codes after a few days, without intervention?
Old 09-22-23, 03:22 AM
  #77
megansdad
7th Gear
megansdad's Avatar
Originally Posted by RadiantX45
@BraveHelios
sounds like overheat. Condition of your hybrid battery filters?
I guess I missed it. Where are the Hybrid battery filters? I know where the vent grilles are, but you're saying there is a filter element too? Where / how to get at? Thanks.
Old 09-23-23, 05:25 PM
  #78
Clutchless
Forum Moderator
Clutchless's Avatar
Received 1,210 Likes on 1,034 Posts
See this for info on the battery cooling fan filters and ductwork.
megansdad (09-25-23)
Old 09-25-23, 07:44 AM
  #79
megansdad
7th Gear
megansdad's Avatar
Wow Clutchless that was PERFECT. I had no idea. Thank you!
Old 09-29-23, 08:42 AM
  #80
MellonC00
MellonC00's Avatar
Default sold my car
Originally Posted by salimshah
Try this script: At the end of each question like, if they say no, ask if they know any shop that can help you.
Hi I have 20?? RX 450 H with the displayed message ".....". Do you guys repair this problem?
Do you replace faulty cells or replace the whole battery?
Would I need to take the vehicle to the dealer for any calibration work after your repair is done?
What sort of warranty do you provide?
When or how soon can you work on the vehicle? Estimated time of repair [I have to make arrangements to have it delivered to you etc]
What is the estimated cost of repairs .. flat labor + cost per cell. <= Shop may choose to break it down or not.
Salim
I sold my car. It took a bit of fact finding mission to find out what exactly went wrong and what was really possible in term of fixing or replacing these batteries.
After my dealer gave me the 8k replacement estimate, I went to a pretty well known local hybrid shop just make sure the dealer wasn't making things up. As it turned out I did need a new battery. the cost there was similar at about 7k. When asked about used or rebuilt batteries, they said that they don't do that anymore as things have been unreliable. apparently there are no Toyota supplied used or remanufactured batteries. Once these guys die, you have to return the battery to the manufacturer. that is the policy (also checked other sources to confirm that is the case). So, officially, there are no "remanufactured" batteries out there. Oh, and, by the way, even with a new battery, the shop could only give me 12 month warranty.
I also checked Prius "specialists" around town. None of these people seemed reliable. I don't know where they get these used batteries but they said things like, "OK. let me send out a notice to my sources. I'll call back when I get a good one." I said it's not like I'm buying a kilo of something bad. don't you just call LKQ or Autozone or something????
financially it didn't make sense to keep the car. I still took a hit on the sale price because I disclosed my current problem but wasn't as bad as replacing the battery. One last thing, this car is not PZEV, which has the 150k mile battery warranty in CA. SULEV cars only get the 100K mile warranty in CA. the general info on various websites, do not make the distinction between the two and just tell you CA requires warranty up to 150K miles. that is incorrect.
Now seriously looking at a Lucid....
edit: here is my cost to drive this car (bought in 2016 as CPO)
depreciation including purchase tax from CA: about 330 per month or 25 cents per mile
repairs: $600
maintenance: $3400 including tires
accessories: $2000 including PPF and other completely unnecessary doodads.
Total cost per mile (not including insurance stuff and annual DMV extortion fee): 30.7 cents per mile
longlt (09-30-23)
Old 09-29-23, 01:38 PM
  #81
salimshah
Forum Moderator
salimshah's Avatar
Received 1,106 Likes on 995 Posts
Thank you for the update. Best of luck as you go forward.
I was hoping that other than a refurbished high voltage battery, there is an option to procure and swap out bad/weak cells. Maybe this is a temporary situation and that option becomes available again in future.
Salim
Old 08-26-24, 09:02 AM
  #82
luckyJ
luckyJ's Avatar
Default My 2011 RX450h with Christmas lights
hi, flew out to purchase this car and drove back home 300 miles yesterday....my brother and mom both had Prius gen 3 and 4 hybrids so kinda got a feel for how they worked/drove...also leased a 2015 RX350 and really enjoyed driving the car (think the only maintenance done on the car was oil changes and front brake pads, after having driven it 45k miles)....I had purchased a Curt trailer hitch for it that I had to take off before returning the RX350 and stored it in my garage for the past 9 years thinking I could use it if I purchased another 3rd gen RX in the future....well that dream finally came true over the weekend....
so the dashboard is seriously lit up....the biggest issues are the hybrid battery and the ABS pump/actuator/module...
list of items to fix:
1) Hybrid battery - symptoms - fan is continuously on, check hybrid system light on dash, engine starts and runs but no battery assistance...
2) ABS brake pump/actuator/module - whining noise after engine shuts off...brakes work fine though
3) Transmission and transaxle oil change
4) Engine air filter/cabin air filter
5) Radiator Coolant flush
6) front struts and rear shocks (leaking)
7) driver's side HID bulb
8) engine hood shocks
9) lift gate shocks
10) front passenger seats (torn), just saw youtube video of swapping out the leather seat covers...OMG!
11) front and rear parking sensors (not working/beeping)
12) engine mounts (clunks a bit when stopping/starting)
13) chirping sound coming from rear of car
I was able to do an engine oil/filter change yesterday and fortunately wasn't able to see any kind of leaking underneath....so far so good
Old 08-26-24, 12:51 PM
  #83
salimshah
Forum Moderator
salimshah's Avatar
Please list error codes?
Your list of items that needs to addressed are up-keep items, which may be needed or already performed by the previous owner. Yes to be safe, performing them again will not cause any harm.
But, to me, making the vehicle road worthy is paramount and there is little sense in performing maintenance at this stage. The vehicle must be determined to be viable. I would not simply make sure that all fluids are present and in drivable zone [above min and below max].
One you bring to a drivable sate, then create an ordered list with emphasis on safety [items like brakes, tires] go on the top and parking sensors & ripped seats at the bottom of the list.
Seems like you have a project vehicle on hand. I hope it does not become a money pit. But then real cost will be based on the price you paid and how much you spend to bring it up to an alternatively similar RX on the market.
Salim
PS: Check out the thinnest of the manuals in the glove box "maintenance and warranty". Check out the service items based on milage and time and bring your vehicle maintenance current.
Old 08-26-24, 10:50 PM
  #84
luckyJ
luckyJ's Avatar
Default Error codes
Here are the codes to my Christmas light dash:
P0A80 Replace Hybrid/EV battery pack
P3013 Manufacturer Specific, Battery Block 3 becomes weak
C1391 Abnormal leak of ACC Press
Old 08-27-24, 11:19 AM
  #85
salimshah
Forum Moderator
salimshah's Avatar
So what is the plan? New or used Traction battery bank or repair of bad cells? Have you looked at who sells what you want.
I would suggest wait for ACC/AC? Keep in mind if you have lost pressure for a while, you will need a new dryer.
Salim
Old 08-27-24, 11:47 AM
  #86
luckyJ
luckyJ's Avatar
ordered the ABS Brake Actuator Assembly and Fluid ($860) and Brake Booster Pump Assembly w/ Accumulator ($575) from Toyota Alabama last night...they were having a 25% off sale and the total was only a few hundred more than the refurbished units off Ebay so figured best to just buy new.
Also placed an order for a new battery from Ennocar in China. $2500 including shipping...expected arrival in 10 days.
Called around a few local hybrid repair shops and all wanted close to $4000 for a new unit installed.....so figured I just purchase on my own and do the install....at least get to learn about these things...need to make sure I get some safe gloves!
Old 08-27-24, 05:02 PM
  #87
salimshah
Forum Moderator
salimshah's Avatar
In for a penny in for a pound approach. Keep us posted.
Salim
Old 08-28-24, 06:27 PM
  #88
Masshybrid
2nd gear
Masshybrid's Avatar
I too have an issue with my 2013 Rx450h (180,000 miles) Check Hybrid AND Check Brake SYSTEM dashlights came on, I've searched high and low thru the forums for guidance but no luck. I thought buying a new refurbished hybrid battery would do it (which I did), but post battery install the lights came back on in 12 hours-so its not the battery. I took to dealer, they said I need a new battery/pack for $6500 (just spent $3000 on the refurbished battery). I'm having battery company come back out, but my concern is that there is a separate issue causing the hybrid system to switch off and the dashlights to come on. Car REVS very loudly but still drives, and brakes work fine. Any suggestions on what else to troubleshoot, and/or replace? Also, anyone know any hybrid expert mechanics/shops in Eastern Massachusetts? My local guys wouldn't touch it. Thanks (error code when I went to dealer was POA80, they also said I need to have my timing cover replaced, and because of these 2 big ticket items wouldn't take the car on trade-which sadly is beautiful/spotless inside and out, but wont pass the state inspection with the error lights on!)
Old 08-28-24, 06:36 PM
  #89
salimshah
Forum Moderator
salimshah's Avatar
See if you can convince some one who fixes Prius hybrid vehicles.
I have heard of better hybrid battery test app ??? Prius App. That should be able to get you more info.
Also please verify that you will not pass emission test. Without hybrid working the vehicle should pass emission test. Please let me know if my understanding is wrong.
Salim
Old 08-29-24, 05:54 AM
  #90
Masshybrid
2nd gear
Masshybrid's Avatar
Originally it didn't pass emissions test because I hadn't driven it enough to flush the emissions unbeknownst to me, but now it wont pass because the dashlights are on. In theory I could reset them, but they likely will come right back on yes?
Quick Reply: My Lexus 450h Warning "Check Hybrid System"
