Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Auxiliary belt?
Old 09-05-17 | 07:26 PM
ukrkoz's Avatar
ukrkoz
Default Auxiliary belt?
I have strange question haunting me.
AC compressor is electric, as it clearly runs when engine does not run.
Water pump - not sure, but then again, if engine does not run, it does not overheat anyway.
What exactly is auxiliary belt then for? Clearly wrapped around AC clutch? And likely water pump? I get water pump, but AC? Is it electric or not? And then how does electric AC run when engine is turned off and nothing spins clutch?
Old 09-05-17 | 09:42 PM
thomas1's Avatar
thomas1
The only belt is the timing belt. The AC compressor is electric. The water pump is driven by the timing belt when engine is running. The Hybrid coolant has a electric pump. The Engine and Hybrid do not share the same coolant system....
Old 09-05-17 | 09:58 PM
ukrkoz's Avatar
ukrkoz
Ok, I seriously doubt it is different on my 2012 Highlander Hybrid - but it surely has small belt running over 3 pulleys one of them being AC clutch pulley and one being main pulley. . Far as I know, RX and HiHy have identical powertrain.
Old 09-05-17 | 09:59 PM
ukrkoz's Avatar
ukrkoz
Ooops, I think I posted in wrong year subforum. Can it be moved to the 2nd generation hybrid, please?
Old 09-06-17 | 09:15 PM
ukrkoz's Avatar
ukrkoz
That's 3.5L engine. What's the belt for?
Old 09-07-17 | 08:31 AM
thomas1's Avatar
thomas1
Yes the first generation hybrid has a 3.3 l engine, and no belts other than timing belt.
Old 09-08-17 | 08:37 PM
ukrkoz's Avatar
ukrkoz
On 3.5 water pump is belt driven. I am absolutely surprised on 3.3 it's electric. Are you sure? Did someone actually LOOK there?
MellonC00
07-19-18 01:11 PM
over40driv
Performance & Maintenance
13
05-11-15 05:58 PM
91LS400vgb
03-17-11 08:50 AM
blkstealthpaid4
07-09-04 02:10 PM
