50k and 60k service
There isn't a tranny fluid change at 60k....just the brake fluid (every 30k).
From Manual:
60 Months or 50,000 Miles
❏ Replace engine oil with 0W-20 oil; replace oil filter
❏ Reset maintenance reminder light
❏ Rotate tires
❏ Visually inspect brake pads, calipers and rotors
❏ Check installation of driver’s floor mat
❏ Road-test vehicle
66 Months or 55,000 Miles
❏ Inspect and adjust all fluid levels
❏ Rotate tires
❏ Road-test vehicle
72 Months or 60,000 Miles
❏ Replace air conditioner filter
❏ Replace brake fluid
❏ Replace engine air filter
❏ Replace Smart Key battery
❏ Rotate tires
❏ Tighten axle shaft bolts (AWD)
❏ Road-test vehicle
From Manual:
❏ Rotate tires
❏ Road-test vehicle
❏ Rotate tires
❏ Road-test vehicle
❏ Rotate tires
❏ Road-test vehicle
When they are in the wrong forum the Mods move into the correct one (2nd gen to 3rd gen). I think they merged your other one because it's all on the same subject so it's probably best to see all the info in one thread....rather than 2 or 3 or 4.
Hopefully you have what you are after and maybe someone will chime in on Toyota dealers in your area.
Maybe if you said a town rather than Northern Virginia, that might also help narrow it down for you. Good luck!
Every 10,000 miles an oil change and tire rotation is needed. At the Lexus dealership this should be less than $100. Every 30,000 miles the brake fluid needs to be changed and again about $100. Every 20,000 miles change the air and cabin filters. This combined takes five minutes and the air filter can be bought on line at Lexus Parts World for $18. The cabin air filter can be bought at Walmart for $18, It is the Fram Fresh Breeze #10285 with carbon and baking soda to filter the air. Wiper blade inserts again can be bought at Lexus Parts World for $20 for both refills and takes five minutes to replace. You are done until 100,000 miles. At Lexus Parts World use cl5 in the promo code for 10% discount. If you go in and ask for the 10,000, 20,000 30,000 maintenance you will be paying big bucks for a lot more items you do not need checked and inspected. Once a year replace the key fob battery cr2032. Keep receipts for everything. I take my oil filter and 5 quart jug of Mobil 1 purchased at Walmart for $24 to my local Toyota dealer and they charge me $20 labor.
