Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
Gas Milage and Hybrid Battery Age
Old 11-02-17, 10:16 AM
RMCA
RMCA's Avatar
Default Gas Milage and Hybrid Battery Age
Greetings,
I’m a new poster here. I have a 2010 RX450h that we purchased in 2013. At that time we were getting mid-24 to low-25 mpg. The mpg has been steadily dropping over the last year to hi-21s. There has been no real change in our driving habits or patterns. Is it possible that as the hybrid battery ages the mpg goes down? I’m at a loss to explain or understand what’s happening here.
thanks in advance for info.
Old 11-02-17, 02:48 PM
ukrkoz
ukrkoz's Avatar
The first indication of decreased battery performance is a reduction on fuel economy and diminished vehicle performance. The vehicle does not get the same fuel mileage that it used to and it feels sluggish - lacking in power during acceleration.
https://hybridautomotive.com/pages/faq#fail
RMCA (11-02-17)
Old 11-02-17, 05:31 PM
RMCA
RMCA's Avatar
Thanks for the confirmation. We will keep an eye out for further deterioration.
Old 01-25-18, 05:36 PM
tempestv8
tempestv8's Avatar
Does the built in systems in the Lexus tell you when to replace the battery pack at all?
Old 01-25-18, 08:13 PM
RMCA
RMCA's Avatar
Default Gas Mileage Decline
Thanks for posting. I’m not familiar with the internal alerts and warnings. I’ve decided to take it in for a diagnostic test. The battery warranty runs out soon, so I’m taking the safe route.
Old 01-31-18, 07:05 AM
Droid13
Droid13's Avatar
I read the linked page. While some of the information on it is modestly useful, in my opinion the information is way too hyped marketing oriented and suggests the owner should be fearful of some normal operations. I was particularly annoyed with the reference to the "third warning". Yes, if stuck in heavy slow/stopped traffic the hybrid battery is going to discharge (especially in the referenced warm weather when A/C is typically in use) fairly quickly, and yes, the engine will start to charge the battery, and yes it will idle higher to run the generator.
But when this happens, no... No evil demons have taken control of your vehicle. You have not lost control of your vehicle because the battery is "forced" recharging. No driver inputs are ignored (unless you consider yourself Jedi material and are trying to use The Force). No need to flee from the vehicle and hide in a nearby ditching clutching your cherished religious symbol wondering if you'll see your family again.
The before and after photos of the battery charge. That's quite a drop. It is common to lose a bar or two, maybe even three if the car has been sitting for a while (NiMH batteries are not known for having great shelf life). A full drop from top to purple would be unusual, but it's also common for the vehicle to tend to heavily rely on electric power after startup while the engine gently idles to warm up, which can drive the battery meter lower, even into purple during the first 2 or 3 minutes of driving.
Old 01-31-18, 04:33 PM
MellonC00
MellonC00's Avatar
In CA, "The battery pack in any hybrid Toyota is warranted either for 10 years or 150,000 miles.
Now, I'm not sure when this policy started but I'd think you'd qualify.
Old 02-01-18, 02:30 PM
takeshi74
takeshi74's Avatar
Wow, OP is old but in response: It's certainly possible. However, it's also possible that you're not aware of or accounting for other factors. 24/25 to 21 isn't a significant delta IMO. Are you relying on what the vehicle is reporting or are you actually calculating MPG?
Old 02-03-18, 08:49 AM
ukrkoz
ukrkoz's Avatar
OP already has crappy mpg to start with. That's moderate driver conventional RX350 mpg. We have one, she does 21-22mpg.
On the other hand, my 2012 Highlander Hybrid with identical to OP power train does 32 summer and 28plus winter in VERY challenging terrain.
Hence, 24 to start with dropping to 21 - either hybrid battery goes down or driver got led foot and does not know how to hypermile a hybrid. Or, lives in Alaska and drives mostly in 40-50 below zero.
Old 02-09-18, 03:03 PM
tus
tus's Avatar
Originally Posted by Droid13
I read the linked page. While some of the information on it is modestly useful, in my opinion the information is way too hyped marketing oriented and suggests the owner should be fearful of some normal operations. I was particularly annoyed with the reference to the "third warning"....
Have to agree with this. The article does ignore quite a few things that were engineered into the system that would prevent you from getting to the states it mentions.
The problems with NiMH happen when you are at either full capacity and charging or completely drained and still trying to pull current. What will happen is the negative or positive electrode will get deteriorated when when over charged or drained. Since the system never fully charges or discharges the battery pack this really isn't an issue. I actually have some 20 year old RC NiMH battery packs that are still fine since I never charge them over 85% or let them run flat.
Getting back to the OP's question, I have to ask, what's the mileage on the car and what maintenance have you been doing? Since the RX is a hybrid, not an EV, and get's all of it's power from the ICE, I would suspect the drop in mileage is from the engine and/or drive train deterioration and not the battery.
Might be time for new plugs, wires, fluids, and whatever else the thing needs to get it back up to where it was.
andynoel78
09-12-14 10:18 AM
xRYD3Rx
05-20-13 03:28 PM
bam
Hybrid Technology
01-11-13 03:21 PM
fulviomm
Maintenance
03-26-09 04:30 PM
toy4two
05-19-04 04:43 AM
Quick Reply: Gas Milage and Hybrid Battery Age
