Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Check Hybrid System light on
Old 12-18-17, 10:14 AM
crigano
crigano's Avatar
Question Check Hybrid System light on
The following warning lights "Check Hybrid System" both "Check PCS System" Went on when we were driving home last night. I just checked the car and the Check Hybrid system warning is still on.
The car is a 2006 with just under 100,000 miles. Is it safe to drive?
What do you think is causing this? I want to be smart when I call my mechanic.
Thanks.
Old 12-18-17, 03:01 PM
Weighit
Weighit's Avatar
I have learned that many things can set those lights off, when it happened to me it was the main big battery failed. Not always is a major item failure. I was able to drive mine to the dealer, about 40 miles.
Old 02-20-18, 12:19 PM
jooksing82
jooksing82's Avatar
Thanks.
First thing to do is plug the OBD scanner and see what codes it shows. Did the car dive any different. Its been two months. What did your mechanic say?
Old 04-24-19, 04:46 PM
Gaetz
Gaetz's Avatar
Default Easy fix
If if you get the Check Hybrid System, one easy thing to try is to simply disconnect the negative post from the battery (10mm). Wait a minute and reconnect. It doesn’t stop the problem from occasionally reoccurring, but it works with our 400h 2009. I think the computer gets stuck in a funny state and disconnecting the battery resets the computer. Notice, others on this list fix the problem by replacing the battery, which would amount to an expensive version of the same fix I am proposing.
Good luck.
Thanks.
rajnarang
Hybrid Technology
37
12-08-23 09:35 AM
lovemy450h
Hybrid Technology
24
08-13-17 02:40 AM
bolido
Hybrid Technology
11-16-16 08:32 AM
maximizese
Hybrid Technology
07-11-16 01:33 PM
devnguyen
CT 200h Model (2011-2017)
10-09-12 11:02 AM
Quick Reply: Check Hybrid System light on
