GS450H regular battery alternatives
#31
Woah! You all know what is coming. Went to go out to dinner last night in Lexi, I push the button to start, and the car lights up like a Christmas tree, my wife says it was making weird noises outside the car, but of course, inside the well insulated car, I only heard a couple of whirring noises. The Navigation screen started blinking like aliens had come down to earth and were messing with the electrical grid. It is times like these I am glad that I am stupid enough to have two cars. Yes the wife has her own car too, so technically three cars. Anyway, the OEM battery was close to 8 yrs. old, but you all were correct, there was no warning at all. Like none. I am just going to go with the OEM though. Not like I need it fixed this weekend if they are not in stock. Need something to do anyway.
Im2bz2p345 (02-07-21)
#33
So I tested the voltage on the 12V battery and it read 9.5. That explains the starting problem. Put my battery tender on it, and it did get up to 12.5 when I disconnected, so at least it takes a charge. In the meantime, I made an appointment at Lexus for a new battery for this Thursday. I know it is going to cost approx. $400, but the car is still CPO until middle of May, and I don't want any problems in case something does happen. Plus, the yellow top batteries I see are over $250, so it really isn't that much more, and it is OEM. Raining buckets in Florida, so haven't checked to see voltage drop overnight, or tried to start her yet. Hopefully, it is just the battery. Sounds like it given it is the OEM and build date was 11/2012. Stay tuned....
#34
Not sure why you’d leave the battery in such a state where you can’t start the car.
all it takes is a multimeter to measure its resting voltage every couple of months to see if it drops below 12v. If so then it’s time for a replacement.
#35
This was the first time the car did not start. It had been sitting only about four days since last being used. I have gone over a week without driving her before with no apparent problems. The good news is the car has started twice and run twice since Sunday after I charged the battery. Still getting a new one put in tomorrow since the OEM one was from November 2012 (first service record on Lexus drivers). If the replacement battery lasts eight years like the original, I will get my money’s worth. Or I won’t be around and it will be Peasodos’ problem to worry about since he is going to be opening his own Lexus upgrade shop.
#36
So the end of the story is that the whole battery replacement ordeal cost me $450 at the Lexus dealer. The battery itself I could have ordered for like $320 plus tax I think, so put it at $350. So yes, I paid $100 for install basically. The coffee and packaged snacks were not that good. On the other hand, I have literally paid jack squat on the other cars I own as one, they have been super reliable, and two, I can do most anything maintenance related on my own. Not hard to change oil and other fluids, filters and windshield wipers are a snap. Even normal battery replacements for $90 every three to four years. If things are not broke, don't pay to have the fixed is my motto. I do not do those Dealer service 15k, 30k, etc. checks for like $400. Not that there is anything wrong with anyone else paying for them. I am a curious mechanic at heart. Ok,enough said. Hope everyone is enjoying their hybrid GS as we are far and few between.
#37
Checking battery performance is as routine as checking tire pressure for me, regardless of the age of the battery. This is to ensure there is no surprises when starting and with the hybrid insufficient aux battery voltage can throw all sorts of error codes by the 14+ ECU's.
#38
Not a bad idea to check the voltage on a regular basis, especially if I am leaving the car sit for stretches of time. Plus, I never get to use my handy dandy voltmeter. Thanks for listening to my boring battery story. Other than that, the seatbelt tensioner, and the sunroof seal, the car is very nice to drive. I actually like the little joystick thing too. Much better than my Acura RDX spin dial thing and monochrome screen.
#39
~ Im2bz2p345
#40
I used a group 35 X2 AGM battery and the fit was nearly perfect. I had to remove some plastic from the foot of the battery to make it fit in the factory battery housing. I did this with a cutting wheel on a Dremel, careful not to grind into the housing. I left half of the material on the foot and it worked well. Otherwise a clean and easy install! 4 year warranty and estimated battery life is 8-10 years.
https://www.batteriesplus.com/produc...wer/sli35agmdp
Im2bz2p345 (08-28-22)
#41
Last year my 12v went. It lasted 10 years. I replaced it with an AGM Duracell from Sam's Club. I recently was away for a few days and drove the car to get some pizza. Car would not go into Ready mode until I tried for 10 minutes. I also notice that my tilt motor for the steering wheel has been running slower. I never have had this problem with my original battery, but I am also only driving 10 minutes to work for the past 6 months. I read in another thread that you need to hook up the temperature sensor or the battery may not charge? In this picture, is this the sensor? In ya'lls opinion, why would the battery not be charging? Am I not driving far enough, or is there some parasitic draw? Do I need the OEM battery? Thank you
#42
Update. I got my battery load tested and it is fine. Had to buy a new trickle charger as my motorcycle charger was not strong enough. I charged battery back to full, and even took some long trips. Battery is still not charging fully. Can anyone answer why it is not charging? I posted a picture of what i think is the temperature sensor. Could that be the problem???
#43
Check with a multimeter, the battery should be at least 12.6v which everything is switched off. You should also check if there is any parasitic current draw. With the car running you should see about 13.5-14.5v at the battery terminal.
The OEM battery has a slot for the temperature sensor / thermistor to be mounted. If you don't have this slot on the new battery, tape up the thermistor to the top of the new battery.
Check if your hybrid falls within the VIN range concerning the Network Gateway module? See BCLexus description. below.
https://www.clublexus.com/forums/gs-...l#post11768837
The following 2 users liked this post by gripau1:
Im2bz2p345 (08-20-24),
spineman (08-19-24)
#44
Thank you so much gripau1! My VIN is definately before the number listed and also my car has lane assist. It doesn't list the GS 450h, but I am going to remove glovebox and check part number any way. My multimeter battery was dead, so I have to get a new one.
Found this online for the new part: https://www.lexuspartsnow.com/parts/...tra2=&filter=()
#45
bclexus (08-19-24),
