RX 450h towing ?
I was planning on buying a 2013 - 2014 RX 450h and pulling our small ( 17 ft, 2900lb) travel trailer around Canada this summer. I'm getting mixed results as to if this vehicle is able to tow that , or anything for that matter? This is the correspondence I received from Customer Assistant Center Lexus Canada!
" Thank you for your recent correspondence.
We would like to take this opportunity to advise that a Towing Package is not an available option for the 2013 RX 450h and 2014 RX 450h.
In addition, as stated in the Owner's Manual, "Lexus does not recommend towing a trailer with your vehicle. Lexus also does not recommend the installation of a tow hitch or the use of a tow hitch carrier for a wheelchair, scooter, bicycle, etc. Your vehicle is not designed for trailer towing or for the use of tow hitch mounted carriers."
We hope this information is helpful and thank you for taking the time to write.
Sincerely,
Hiyem Zabian
Customer Assistance Centre
Lexus Canada "
Anybody care to comment on this ?
Sincerely,
Hiyem Zabian
Lexus Canada "
Take this as you see fit since this is your vehicle, I have a 2010 which I put a hitch on, but had the factory trailer wiring and towing oil cooler package already present. We don't do it a lot, but the odd utility trailer is what we use it for.
Is your's an AWD? Lexus does not recommend towing with the 2wd but the AWD is fine.
The chart on p.377 for my US RX450h has a limit of 3500lbs for one with the tow package. I've pulled my ~2500lbs boat with my '13 AWD 450h without any problems.
Of course there is also the problem of the electric only in reverse on hills and with heavy loads.
Sincerely,
Hiyem Zabian
Lexus Canada "
Sincerely,
Hiyem Zabian
Lexus Canada "
Thank-you all for your replies. I am referring to the AWD model. I don't believe the 2 wheel version came out until sometime after 2014? Not sure though ! I've just read about the reversing problem when towing also. What I don't understand is that there is a towing package available and then the company tells me its not designed for towing, basically anything that uses a tow mounted hitch! This is super frustrating as I really wanted a RX 450h but now I'm just not sure it's is worth it since I will be towing with it
I'm thinking it would be fine with a smaller load but I might be pushing it with a 2800lb camper?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Thank-you all for your replies. I am referring to the AWD model. I don't believe the 2 wheel version came out until sometime after 2014? Not sure though ! I've just read about the reversing problem when towing also. What I don't understand is that there is a towing package available and then the company tells me its not designed for towing, basically anything that uses a tow mounted hitch! This is super frustrating as I really wanted a RS 450h but now I'm just not sure it's is worth it since I will be towing with it
http://www.toyotanation.com/forum/63...er-hybrid.html
Same power train. Should answer your question.
There is no power train difference between Highlander Hybrid and RX hybrid. Links are for hybrids only. People tow large boats with them. I literally used mine as a truck for 6 months, hauling and towing and both same time. Link I referred to is in toyotanation Hybrid section, specifically - Highlander Hybrid. About the only difference I know, outside of looks is that RX has shocks in the rear and Highlander has struts. Maybe because it's larger vehicle cargo area wise.
PSD is not CVT. Only called that.
Abrar (05-03-23)
It appears you are looking at older used models. I don’t know much about them. My 2016 RX 450h has the tow package & can tow up to 3500 lbs. My model 450h is AWD, but the rear is powered solely by an electric motor & a computer. I have towed my 6X12 dual axel trailer locally (25 miles or so), but not cross country. I have had it up to highway speeds & it did OK. I do think heavy wind will be a problem. Previously, I had a V-6 ½ ton pickup that struggled some in the mountains with this trailer, but overall it wasn’t bad.
Newer 450h models will do what you want. If not, consider looking at used VW Touareg TDIs. They are quiet, ride wonderful, get good mpg & have almost as much luxury as the RX. VW has fixed the V-6 diesel & it has been certified to sell again. They will tow at least 5,000 lbs or more.
Thanks for the replies. I was looking at a 2014 RX 450h and was just about to buy one when I received the email from Lexus stating "' We would like to take this opportunity to advise that a Towing Package is not an available option for the 2013 RX 450h and 2014 RX 450h. In addition, as stated in the Owner's Manual, "Lexus does not recommend towing a trailer with your vehicle. Lexus also does not recommend the installation of a tow hitch or the use of a tow hitch carrier for a wheelchair, scooter, bicycle, etc. Your vehicle is not designed for trailer towing or for the use of tow hitch mounted carriers. We hope this information is helpful and thank you for taking the time to write. Sincerely,
Hiyem Zabian
Lexus Canada ""
I'm not sure who is right and who is wrong and why Lexus states in their 2014 RX450h specs, that I downloaded off their site, that it can tow up to 3500lbs, then send me an email stating " it's not designed for towing " !! What ever, I decided to forget about buying the RX450h and using it to tow our camper. I just want to be able to enjoy myself and not worry about the vehicle I'm driving ! Thanks to everyone who replied and I hope this helps out anyone else who is thinking about towing with the RX 450h.
Hiyem Zabian
Lexus Canada ""
I have just received this response from Lexus Canada who had sent me the original email warning me away from towing. I hope this clears up some of the issues about towing with a 2014 Lexus RX 450h. Too late for me though. I already bought a different make.
Dear Mr. Harvey:
Thank you for your reply.
We would like to take this opportunity to advise that upon further research, the 2014 RX 450h and 2013 RX 350h, are equipped with a towing package with the towing capacity for both vehicles is set at 3,500 lbs (1,585 kg).
We would like to direct you to the Owner's Manual, page 306 under Trailer towing regarding the 2014 RX 450h and page 373 under Trailer towing regarding the 2013 RX 450h states the following;
"Your vehicle is designed primarily as a passenger-and-load-carrying vehicle. Towing a trailer can have an adverse impact on handling, performance, braking, durability, and fuel consumption. For your safety and the safety of others, you must not overload your vehicle or trailer. You must also ensure that you are using appropriate towing equipment, that the towing equipment has been installed correctly and used properly, and that you employ the requisite driving habits.
Vehicle-trailer stability and braking performance are affected by trailer stability, brake performance and setting, trailer brakes, the hitch and hitch systems (if equipped). To tow a trailer safely, use extreme care and drive the vehicle in accordance with your trailers characteristics and operating conditions.
Lexus warranties do not apply to damage or malfunction caused by towing a trailer for commercial purposes. Contact your Lexus dealer for further information about additional requirements such as towing kits and so forth.
We thank you once again for taking the time to write. We apologize for any inconvenience.
Sincerely,
Hiyem Zabian
Lexus Canada
Dear Mr. Harvey:
Sincerely,
Hiyem Zabian
Lexus Canada
I have a hybrid 450h. I have several lightweight wooden rowboats (I build boats) and I use a couple different trailers to take them to various local lakes. I use these boats for a workout and once in a while to keep the local bass population healthy by never catching any of them. A few years ago I tried to get some info on a trailer hitch and got numerous Thou Shalt Not responses form dealers nearby. Has that changed? They don't understand or care that I don't put the car in the damn water. So it's not a question of whether I should, it's a question of how? Anyone have any luck getting a hitch on one of these? Has anything changed? My wife can get hitch for a Prius, why not one of these?
