ES300h footwell light
i am not sure if it's the sensor or switch or option selection, my footwell light went dim i checked the power it's running 2.56 i even checked the light under the internal mirror that shines under the shift gear it's off can someone please help me to see what the issue
i checked on both sides they both dim any ideas?
I will say one last thing. Have you taken it to the dealer? You have a 2015, so unless you've driven way over the national average mileage, you should still have a warranty. Also, I'll bet there's nothing wrong with the way they're operating.
good day Mike, what i noticed yesterday the light is on all the time it doesn't go off so i had to take off the light so it wont drain the battery which it doesn't take that much power.
footwell light is on all the time under the dash i found the wire that connects to the hub but doesn't do me much good not sure...I need to know what i need to change the part what part is burn that makes the light on all the time
Are you saying that the foot well lights stay on even when the engine is turned off and with the doors closed? The foot well lights are supposed to stay on when you are driving, and they are supposed to turn on when the doors are opened. If that is what is happening with your car, it is normal operation. If, on the other hand, they don't turn off and stay off after about 30 seconds after the engine is shut down and with the car's doors closed, that is not normal, and, as others have suggested, you should have the dealer check out the car to see why that is happening.
yes that's exactly what i am saying it's stays on all the times i put the alarm on still stays on
stays on 24/7
so strange the light gets little brighter when i put the alarm on also
stays on 24/7
What alarm are you talking about? Do you have an aftermarket alarm system? If you do, that could be the cause of your problem.
drgerry
08-30-20 12:57 PM
BlueCrabby
RX - 1st Gen (1999-2003)
11-30-19 10:23 AM
