2006 RX400h - no sound, AMP OK - checked via diagnosis tool
Anyone, please help - No sound in my Lexus RX400h (2006). There is no sound, no matter what source is selected. Volume numbers go up & down, but no sound. Checked the Amplifier thru the "hidden menu" diagnostics, and AMP says OK. Please help. Thank you.
I have found a post ...
"It's a common problem that the DVD drive stops working and at the same time the music disappears.
If you still see the volume level display when turning the volume ****, the amplifier is likely still working and the problem is in the headunit"
Anyone out there knows, how to force the DVDs/CDs out of the headunit (PN 86120-48B70)?
Thank you
Thank you
