Please help - RX 450H Stopped suddenly on the road - IGNITION ON SIGNAL
Hi ericsan13,
Thanks for replying. The thing is that I imported this car from another country and still not registered under local dealer warranty. I will try to change battery first and hope it will help. Otherwise will take it to dealer but without warranty im sure they will charge me a lot
as well. With EV mode the car will drive only 20miles or so. When 12V battery went dead what kind of charger did you use? A trickle charger over night some thing like that or quick booster type charger??
I've been thinking along the asme lines ever since this thread was started. If they jumped this battery while it was connected or put it on a battery charger that doesn't address sensitive electronics, then the RX's electronics could be damaged. I would have disconnected the battery cables prior to any charging, trickle or otherwise.
corradoMR2
RX - 3rd Gen (2010-2015)
19
02-02-14 01:43 PM
barnett
Hybrid Technology
07-11-08 02:30 PM
