NX300h 2018 Bad designed door seals. A lot of dirt and mud stuck inside the doors. ju
NX300h 2018. Discovered a lot of dirt and mud on inner lower sides of each front door and on in lower corner of each rear door. went to delership and the told me that it's the way it is designed. called Lexus openned a case (#1808161611 on 08/16/2018. Got a call from them today that nothing they can because it was designed that way. This is ridiculous. The should disclose that design flaw.
Lexus refuses to correct the problem.
Check out this solution from corradoMR2: https://www.clublexus.com/forums/nx-...-seal-fix.html
While some said the seal issue was minimized with the 2016 model compared to the 2015, my 2017 has the same problem.
