ES 300h - Hybrid battery replacement.
#46
Just inspected the fan blades on my 2014 ES300h with 117k miles (no filter in 2014 by the way). The blades are still 99% open and functional although there is a thin layer of "dirt" clearly visible. Conclusion - no action necessary till 300k or more - at which point the battery may need to be serviced anyway - so the fan can be cleaned then.
DISCLAIMER: I only occasionally have pets in my car (annual vet visit), usually keep it clean and don't drive in dusty areas with windows open. YMMV
Picture taken with a borescope:
jollick (08-04-20)
#47
Checking the blower filter is part of every 5k service listed as "Check HV Battery Cooling Intake Filter" but it's really easy to do yourself.
In the back seat or the floor of the right side there is a plastic cover with a vent being held in place with a plastic screw and some clips. Pop that cover off and the filter is attached to the plastic cover.
i found this out looking into it more details
but how can I do it on this if the filter is only available for sale and service replacement on 2019 and newer
then how do I clean the filler or fan on the 2016 ? i dont' see the part you posted that would be in the back seat on the right side could you please post a picture of it so I can see what I need to look for on the right side ?
thank you
#48
i don't know if the filter I see on the backseat area when the door is open on the left side there is a vent that i always wondered what it was but not sure how the heck to remove it or if that's even the real issue can you confirm where yours is that you located ? do I have to take the back seat panel apart or do I have to pull the panels inside the trunk out to access where the battery is to check this ?
#49
This is the air intake, but I do not know whether there is a serviceable filter in there or not. I can see the openings in yours are full of lint or something. I would sure try to find a strong vacuum and attempt to suck that out. I would NOT use air because you could just blow it through any filtering element.
i see the top of this panel shows the words air bag so I'm afraid to try and pull it out I dont want to have a air bag deploy or malfution but I am thinking if I can pull that panel it would be easier to take a compressor and blow out the lint from it
#50
Looks like 2013-2015 do not have the fine mesh filter while 2016-2018 do. If you have the mesh just clean it with a vacuum cleaner (and maybe a small brush) and check every 5k or so that it stays clean.
#51
NdYAG (08-04-20)
#52
Ok so I went to the local car wash they have these air compressor houses to blow dirt out of areas I use that and the vacume to get all the link out if the vent in my left rear door area
But now thinking I should still pull the panel off to get out flint or dust that has accumulated behind that but can’t figure out how do I need to remove the back of the back seat to pull that out or do I just tuck my finder between the set side and the panel get a good grip and pull it what ?
#53
See
#54
According to this service bulletin from Toyota for 2013 and 2014 vehicles, the only instance where they recommend a blower cleanup is in very specific, severe use scenarios
1) The vehicle is used for over 15 hours per day.
2) The vehicle is used over 6 days per week.
3) The rear seat is used over 50 times per day.
#55
#56
Yours has a mesh screen - so it does apply.
#57
i’m worried that when I went to the car wash to use their vacuum in there air compressor to get mine cleaned off is I got all the wind out of that that maybe you weren’t got pushed behind the screen so what I wanna do is get that screen panel out so that I can get behind that but I’m struggling with trying to figure out the exact procedure to get that panel out I don’t want to pull the panel and then find out that there is a clip that needs to be removed somewhere and then after breaking it it seems like no one‘s able to answer or I haven’t or I missed where someone did answer explaining how do I do that because what I wanna do is pull that mesh screen trim Oh and then take a microfiber towel or a lint brush or something behind that and be able to pull out any wind or dirt that is beyond that or that might’ve got pushed through the screen mesh filter
#58
This is the dismantling manual I found.
As always, a disclaimer that it can be a dangerous process and your Lexus might not need it. if you see the instructions in the SB above, only vehicles like taxis might qualify for the amount of use you would have to be doing in order to have to clean up the blower once in a while.
jollick (08-06-20)
#60
would it be possible for you to post a picture more clear of what I need to look for this fan ? i want to check it in my 2016 ES300h and I'm not sure I'm still lost on how to find it I don't understand how to locate it because what I read is something about a panel on the right side back seat area but I don't know if that's on 2019 and up only which is when the filter was able to be replaced
