Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Gear shifter is hard to move
Old 10-20-18, 07:35 AM
topgun303
topgun303's Avatar
Question Gear shifter is hard to move
I own a 2007 RX400h with 160K miles on it. Recently, I have to put a lot of pressure when moving the gear shifter between gears. Is the shifter assembly as a whole bad or shifter cable binding. If someone here had a similar issue and knows a fix. I am also looking for instructions on how to remove the shifter assembly.
Old 10-21-18, 09:07 AM
ukrkoz
ukrkoz's Avatar
There was few folks in Highlander Hybrid forum with similar issue. Ended being shifter lubrication issue down in the console. Some plastic bushing....
Old 10-24-18, 07:04 AM
daddiojigg
daddiojigg's Avatar
well i guess as they say timing is everything. Just returned from a 4k miles trip with wife's Rx350 and jumped back into my hybrid and the first thing i noticed was how 'stiff' the shifter was. I attributed it to her's just being 'looser' than mine and maybe the fact that mine had been just sitting in the cold for two weeks but i figured it would work itself out. After three days it still feels 'stiff'. I can't remember if this seemed normal to me prior to me taking her car for the vacation. Now you have piqued my interest , i'll check the HL forums. Thanks
Old 12-20-18, 08:01 PM
myw
myw's Avatar
your shifter cable is likely getting old and frayed - first easy fix solution is to use wd40 or white grease under the car exactly where the shifter cable and the metal linkage point is to the transmission - that should do the trick.... and i would continue doing that every-time the car is on a hoist (ie. every oil change). eventually the shifter cable itself may need replacement.
nikovdh
06-25-14 02:21 AM
LexusGS3
GS - 1st Gen (1993-1997)
06-27-03 03:20 PM
FlyLexus
SC- 1st Gen (1992-2000)
02-01-03 07:38 AM
Quick Reply: Gear shifter is hard to move
