lexus RX 400 h 2006 èproblem at the starting
I have a Lexus ùRX 400 h year 2006 , at the starting I have a problem with the word READY tghat do not appear , even if gear handel is in Park etc etc....the READY appear after several times at the beginning it appear after one time ...but time after time I need to try more times ...
You have 3 options.
1. you got lemon for 12V and it went kaput. Happens. Needs to be tested. if you got the OEM or exact match battery, it's deep cycle one, so it needs to be tested accordingly.
2. Your hybrid battery is "getting there". reason being, it is charging 12V via inverter. If it does not have enough juice to do so, 12V is undercharged.
3. 12V charging system is malfunctioning.
Actually, there is #4. You have corroded 12V battery cable terminals, resulting in high resistance and poor power supply to the system.
hello
thank you
yes I suppose this
I will start with the battery first ..the contact and so on
I know for sure the inverter was replaced on warranty when the car was 60000 km old should be ok, but I will take a look also for that
at the last place ...hybrid battery ...crossing my finger it will be just the small battery
I will inform you ...I will do this week end
thank you so much for your help
thank you
yes I suppose this
Peterzu82
Hybrid Technology
12-18-17 03:03 PM
