Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Modern head unit addition without display sacrifice
Old 12-27-18, 10:18 AM
ukrkoz
ukrkoz's Avatar
Default Modern head unit addition without display sacrifice
CREDIT GOES TO DYLAN DOXEY
I bought my 2006 in April. I for sure wanted the cassette player out from day one. In addition to that, the Navigation was belly up and I wasn't seeing anything that suggested that it could be repaired. Some updated tech was a must for me.
I was able to install an Android without sacrificing the main multi-purpose display at all.
It wasn't entirely easy. Apparently the energy monitor was designed to need the cassette player to function correctly. I don't know what the logic was there. But with some experimentation I figured out that the sole purpose of the 12 pin connector (with only two pins used) is to signal the multipurpose display that the cassette/stereo unit is installed. All the cassette/stereo unit does is apply a 70ohm resistance. I didn't happen to have a 70ohm resistor laying around, so I tried a random one from my scraps bin ...
There is also the matter of the steering wheel controls.
From left to right, that is SW2, SW1, SWG. There's no need to buy a fancy black box. You just need to connect those three lines to your new head unit as labeled. (I just happened to have a Toyota 20 pin connector that works for this in my junk bin.)
For the rest of the connections, the Metra 70-8113 adapter harness did the trick.
I'm planning to add a rear-view camera next ...
Old 12-27-18, 10:20 AM
ukrkoz
ukrkoz's Avatar
I am only posting this from toyotanation as generla guide. I did NOT do it personally, don't ask me questions. I am pretty sure it should be about same for Lexus hybrids though.
dkotoric
07-18-23 12:25 PM
peasodos
09-29-22 11:45 AM
jdm93400
02-15-18 08:00 AM
longbeach9
02-29-16 08:53 AM
Quick Reply: Modern head unit addition without display sacrifice
