A/C error code unable to find. Code 62
Hi,
Recently, my 2006 rx400h starts exhibiting a weird issue: I get cold air out of the vents if temperature is setup on a high setting. Running an a/c diagnose, I get the errror codes 21, 24, and 62. Although 21 and 24 are common codes I couldn’t find code 62. Perhaps a gentleman with more knowledge can step in. Many thanks.
As you apparently know Codes 21 and 24 refer to the Solar Sensor circuit Passenger Side and Driver's Side
Code 62 points to the "Room Humidity Sensor"
