Ls600h transmission fluid change process
Hi. I have 08 Ls600h 196k. I started fluid change and hit some problems. I can’t find fluid capability in transmission. I drained about 7 qt of old fluid but when I started refill, after 5 qt it started to come out of overflow drain.
any idea why?
do you know capacity?
any idea why?
From the owner's manual... My sense is that you've drained fluid from areas that cannot be easily replenished without going through the entire process, allowing new fluid to circulate through the system, etc.
https://www.clublexus.com/forums/ls-...exchanger.html
Thanks
I believe you're on to something about doing the full drain/refill vs partial. I think it may have something to do with temperature as well. See post linked below for further help, this was a 460, but the process should be similar.
When to check
Should I open overflow when engine runs or when it’s off. Because when engine runs I don’t have anything coming out but when engine stops fluid starts to run
You need to check the fluid level when the engine is idling. You also need to wait for the transmission to reach the specified temperature. As your service manual indicates, you need to wait for the transmission temperature to be between 30-40C (68-104F) to unscrew the fluid overflow bolt to check the fluid level. When there is no fluid coming out while the engine is idling at 30-40C, it means that there is not enough fluid in the transmission. You need to add transmission fluid and then re-check the fluid level when the transmission temperature is between 30-40C. (Note, for LS460, the transmission temperature for checking fluid is 35-42C or 95-108F)
fwhomeboy (04-12-19)
Bridging cable.
Indeed, a cable is a simple way to check the temperature. Thanks for sharing the information. On the other hand, I found it easier and more accurate to use Techstream to check the temperature. Since I did transmission fluid changes so many times because of the "strawberry milkshake" problem on my LS460, I feel that I have mastered the process of checking transmission fluid with Techstream and can do it in just a few minutes. Here is how I do it on my LS460:
1. Drive the car onto a raised stand and make sure the car is straight flat level (I check it with a box level ruler)
2. Turn off the engine. Break loose the overfill bolt but don't unscrew it
3. Wait for the transmission to cool down
4. Connect Techstream to the OBD port under the dash
5. Start the car and launch Techstream to view the transmission temperature (it takes about 90 seconds for the transmission temperature to rise one centigrade degree)
6. While firmly press the brake pedal, move the transmission lever to each gear every 2 seconds to make the transmission fluid evenly mixed
7. When Techstream shows that the transmission temperature reaches 35C (for LS600, it'll be 30C), while the engine is idling, remove the overflow plug
8. When the transmission fluid from the overflow hole becomes a "thin stream", install the overflow plug and torque it to 15 lbf. Done.
2. Break loose the overfill bolt but don't unscrew it
yyymmm31 (04-14-19)
Agreed that the wire method may be faster for some people. For me, it is faster to plug in the Techstream connector to the OBD port and then just read the Techstream's screen for the exact transmission temperature. However, disagree that the wire method is the preferred method by factory (Lexus/Toyota). Lexus/Toyota certified technicians were trained to use Techstream to replace transmission fluid, although some experienced Lexus/Toyota technicians count the number of minutes after turning on the engine to estimate the transmission temperature (e.g., in summer, wait for 5-8 minutes; in winter, 10-12 minutes). They can do so because they are experienced and have done it so many times. Just ask your Lexus dealer's service shop how they replace the transmission fluid and they will tell you how they do it (and justify charging $250 for doing it).
ALK (04-13-19)
I paid my Toyota dealer 149 bucks to do mine. Not worth the aggravation and, "what if I didn't use the right amount of fluid"...etc. They definitely used Techstream at my dealership.
OP, hopefully you've gotten the answer you needed from the procedure descriptions above. To clarify, with the engine running the transmission pump runs which pulls fluid up and out of the pan into the internals of the transmission. Without the engine running all of the fluid is settled in the pan which is why you're showing it full at less than published capacity. Accurate levels are established with the pump running. Good luck.
stopdrpnro (02-27-20)
