Any trailer hitch for the RX450HL?
#32
#34
Hi New450HL,
Thank you for posting your pics.. Looks perfect! Did you have to perform any modifications to do the install? I have been looking into putting on a hitch for our 2020 450HL. Curt and Draw Tite does not confirm that make one for the 450HL.. LOL.. Thank you so much, your reply could save me a bunch of anxiety..
#35
Hi New450HL,
for the life of me I have not found where to plug into wiring harness for trailer lights. Don’t think I ever tow (use it for bike rack) but nice to have just in case.
#36
I did not have to make any modifications but I hear the 2020 rear trim is more of a tighter squeeze where you would either bolt and torque it into place squishing about 1/8” of trim or you can cut. I don’t know this to be 100% true the trim hangs slightly lower on 2020. Some say kick sensor is a problem with trailer hitch on but think that can be programmed to not activate. I get to use the force Placing my hand over the L emblem on my 2019 which my 3.5yr old son LOVES thinking he is like Darth Vader.
#38
Hi, would appreciate it if you can share which part of the vehicle setting is this located (the ability to to turn off kick sensor) . Thank you
#39
Hi, I just checked that this hitch receiver model is made specifically for the rx 350 L and it worked fine with your rx 450hL ? Did you install it yourself ? I went to u haul hitch super center and they won't even try the one made for 350L if it fits the 450hL because they can't guarantee it. I do have a 2020 450hl. Thanks for sharing.
#41
Finally Done with wiring kit on non-tow package 2018 450HL
I bought the
Non splicing (clips over top of wires) wire kit for non tow package 450-HL.
I have attached a picture. I got a local trailer business to install as they had to take out the rear tail lights so that they could test the wires at the source instead of poking through wires.
also I don’t have pictures of install to tell you the wires to clip.
So this system reads when their is voltage to the wire and copies that signal.
works great.
Again there is differences between the models and this combo works with the 2018 450-HL.
Also, this is just for towing my very small trailer for Reno’s and snowblower as well as bike rack. This model, was not intended to pull motor homes Or large trailers because it will ruin transmission. Tow package on non hybrids have tranny cooler and larger oil pan.
FYI for other users reading.
#42
Thanks.
#43
Hitch took 6 months. Thanks to “New450hL”
I bought the
works great.
I bought the
works great.
Therefore THANKS for info on the wire harness you installed. I will get the same installed for the rare occasion I need to tow a trailer I know I am fully ready.
#44
RX450HL Tow Bar
Hi, I've just had a detachable towbar fitted on my Rx450HL. I'm UK 🇬🇧 based and Lexus dealers couldn't help. I contacted many fitters and only http://telfordtowbars.co.uk managed to address the issue. They fitted a detachable towbar with a 7pin connector. The tailgate still operates with the kick sensor too. I also purchased the Thule 3 bike rack, Thule roof bars & Thule roof box. Bill & Andrew are both amazing people and did a fantastic job. Please note: the RX450HL can not tow but can carry a bike rack/carrier.
RX450HL with full Thule fitout & detachable towbar from http://telfordtowbars.co.uk
#45
A few weeks ago I installed the Curt C13394 hitch from etrailer.com on my 2020 RX450hL (https://www.etrailer.com/Trailer-Hitch/Curt/C13394.html). Etrailer and Curt don't seem to know that this hitch which is meant for the 350L does also fit the 450hL but it fits perfectly. The install was fairly easy, I did it all myself except I had my son help me to lift it into place and get the first few bolts in place. The videos on etrailer are helpful, but there isn't one for an RX for this hitch. However, there is one for another hitch that installs very similar, so suggest watching the Lexus RX350L install video here: https://www.etrailer.com/Trailer-Hit...ite/76156.html. The biggest task was probably cutting the driver's side panel to go over the hitch since they don't give you a template or anything. What I did was pushed it into place to see where it hit the hitch and then tried to just trim the minimum amount necessary with a Dremel and a cutting blade. The second picture shows the panel after I trimmed it and re-installed it. The third picture is the front part of that same panel to show where I trimmed it there.
I won't be towing with this vehicle so I only installed the hitch and didn't bother with the electrical hook up. I just need it for a bike rack and possibly a cargo carrier. I bought a 1-Up USA Equip-D Single (https://www.1up-usa.com/product/equip-d-single/) bike rack plus one Equip-D Add-On (https://www.1up-usa.com/product/equip-d-add-on/). Most of the time I only need to carry one bike so this will allow me to have a small single bike rack most of the time and I can add room for a second rack only when I need it.
I'm very happy with this setup. Here are some pictures:
nitalice (04-09-21)
