Maintenance for 2008 RX400H
5th Gear
Hi all, I'm new to the forum and seeking some maintenance advice for an 2008 RX400H with 181,000 miles that I just purchased from my father. Car is in great condition and taken care of, but since the manual doesn't provide a maintenance schedule beyond 150k miles I'm wondering what should be done in terms of keeping it up.
Outside of oil changes, cabin air filter replacement, tire balance/rotations that have been performed regularly, the last major service was completed at 120k miles. At that 120k service, the following was completed:
Thank you all so much in advance.
- Transmission flush/fill
- Rear differential flush/fill
- Replaced brake fluid
- Replaced front brake pads/resurfaced rotors
- At 150k brake fluid was replaced again, and engine coolant and inverter coolant were replaced
Spark plugs should have been done at 100K miles.
Otherwise, you good on fluids. ATF is considered lifetime, so you are good there.
Unless your engine has timing belt, you good.
rkriley24 (02-25-20)
