Hybrid TechnologyUnique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
Does anyone know if these LED headlights have "bulbs" the can be replaced? Or does the entire assembly have to be replaced when the low beams finally "burn out?"
Had the same problem. LEDs not working. We couldn't see any access to bulbs for the LED part, so I believe you should check first if those 2 modules (attached) work properly. Especially the Light Control LED.
