Wet carpet and P0AA6. Will it dry out Or will I have to replace main relay?
New to me RX 400 H has a P0AA6 code and wet carpet under the rear seats. I have read up on this, and seeing where it is recommended to replace the drain and main battery relay. I’m wondering if I open the battery up and replace the drain if the relay will dry out on its own Or will I have to replace it. It’s $400 at the Lexus dealer. By the way the prior owner replaced the relay about a year ago. They obviously never repaired the water leak. Will be checking the body seams back by the hatchback struts
New to me RX 400 H has a P0AA6 code and wet carpet under the rear seats. I have read up on this, and seeing where it is recommended to replace the drain and main battery relay. I’m wondering if I open the battery up and replace the drain if the relay will dry out on its own Or will I have to replace it. It’s $400 at the Lexus dealer. By the way the prior owner replace the relay about a year ago. They obviously never repaired the water leak. Will be checking the body seems back by the hatchback struts
Thanks to Paul Cortez at Art’s Automotive in California and his article about this that I found on the Internet and his being willing to communicate back-and-forth with me by email.
